Results 1 to 6 of 6
Thread: Air intake
    Junior Member Two Rings
    Oct 20 2022
    Glasgow, Scotland
    Air intake
    Grr
    Not only does this not fit properly (and doesn't seem to want to stretch to slot in properly) but there are also a few splits in it, which explains my MIL!
    Is this the source of a very quiet, high pitched whine/squeal noise i take it?
    Either way, since I need to replace it, are there any recommended upgraded ones at all?
    Thanks as always!
    porsche cayman s 0 60
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Shouldn't cause a CEL(mil), its pre MAF. Maybe heat gun, and stretch it out.. Or replace with new.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    take it completely off the car and take a look inside the duct. There are grooves/slits the pieces need to slide into to alight properly.
    2019 SQ5 Prestige
    Account Terminated Four Rings
    Oct 15 2013
    Look at jayz spam the site. Jesus.
    Oct 20 2022
    Glasgow, Scotland
    Haha I'm very glad for his help!
    - - - Updated - - -
    Ok thanks
    If I'm thinking about a stage one remap is this the ideal time to get an upgraded one?
    Is there any recommended?
    Established Member Two Rings 007J's Avatar
    Jul 28 2021
    2006 A4 Quattro
    TN, USA
    Upgraded air intakes do basically nothing for us. Just cut off the bottom of the stock airbox, add a pipercross or K&N air filter, wire mesh over the cut out, and boom, you have whoosh noises and turbo spool sounds. For tunes, maybe consider stage 2 before you decide. For tuners I'd recommend Motoza.
    034 MS RSB & Adj Endlinks, Snub & Bracket, HD Tierods, Adj Front Crtl Arms, Dif inserts, HPFP
    CTS Turbo VC, CC, HFC, FMIC
    ECS Poly engine mounts, Turbo Inlet, Skid plate, Carbon Wing
    Motoza Stage 2 E85, Raceland Ultimo CO, SilverProject Adj Rears, PowerStop Z26 F&R, APR S3 Injectors & Coils, RS4 FPRV, R8 fuel module, GFB DV+, Custom CAI, Brisk plugs, TT DP, 6.6bar custom FF, Wasa FW BSD, Asanti Orion 19x8.5, Maxton Lip, LED Spec D HL, BFI Shifter, Hella Horns, Conti SportContact 6
