Results 1 to 7 of 7
    Oct 23 2022
    Vermont
    Need help/diagnosis
    I have a 2013 a4 allroad. (2.0t) It just started making a rattling/ticking noise when I accelerate. It's pretty faint but noticeable. I don't hear any rattling/ticking when the car is idling. I also don't hear anything when I rev it when its stationary. I don't hear anything when the car is rolling at a decent speed either. Its only when I accelerate. Anyone know what this could be?
    Thanks
    Dec 17 2021
    B8 A4 Avant, 2021 Tiguan R-Line (wife), 2022 Silverado 1500 4x4, Volvo 245+T
    North Carolina
    CEL present? Any codes?
    Oct 23 2022
    Vermont
    I checked. There are no codes.
    Dec 17 2021
    North Carolina
    Lots of things could be happening when under load like that. Could be as simple as a loose heat shield or a stray bolt/lost tool somewhere in your bay or undercarriage.
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    I had a similar issue. It turned out to be my spark plugs. I also eventually changed out my coils. Issue hasn’t returned since. See below for my account of the issue - not sure if you are experiencing the same:
    Tick under heavy load/acceleration with check engine light flash
    https://www.audizine.com/forum/showthread.php?t=930633
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
    Oct 23 2022
    Vermont
    It's probably not the spark plugs because I'm not getting any codes and I haven't had a check engine light or anything. I'm thinking something is loose somewhere.
    Aug 06 2019
    Philadelphia
    Need help/diagnosis
    Quote Originally Posted by dylanlutz View Post
    I only got the cel when I pushed it very hard and it flashed and then went off. During normal driving, the tick was on acceleration - no cel and no codes. A scan with obd eleven showed high misfire counts. What are you aiding to read your codes?
    I know the noise occurs on acceleration but is it constant or does it increase as speed goes up?
    2002 SV650 - SUZUKI
