Results 1 to 2 of 2
    Junior Member One Ring
    May 30 2019
    Iowa
    stock fuel pump and engine speed sensor
    I have a 2001 audi a4 1.8t I need a stock fuel pump and a engine speed sensor. let me know if you have one available.
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    I’m not sure I’d trust either of those things used, and would recommend going new.
    RockAuto is a good place to get parts for cheap. They have a crank position sensor for $35 for either Bosch or NTK, both reputable brands. They have them as low as like $10 for some off brands. They also have a fuel pump with the isolating cage (brain can’t remember the correct name right now) for $60. That said, I have the pump itself from that $60 kit you can have if you pay shipping and PayPal fees. I bought one because I needed the cage, not the pump, to install a high flow AEM pump. A lot of times, you can reuse the cage. Mine was deteriorated beyond repair.
    Sent from my iPhone using Tapatalk Pro
