Results 1 to 3 of 3
Thread: P0140 P0141
    Established Member Two Rings Fiction1990's Avatar
    Sep 23 2021
    Las Vegas
    P0140 P0141
    I kept getting a P420 with a hfc. I tried spacers and didn't work. I found a diode trick and tried that, no more 420 code but now I have the other 2. I thought maybe I had broken the heater wire when I was moving everything around putting in the diode, so I changed the sensor. Brand new bosch and still having same problem. The P0140 doesn't usually set it just stays as pending. What do I need to check besides resistance on the heater circuit?
    Thanks
    09 A4 B8 3.2 lowered on raceland coilovers, 20x8.5 shift spring
    Sold 04 A4 Avant Quattro 1.8T 6m/t, Bilstein coilovers, Magnaflow catback, Hotchkiss sway bars f/r, fmic, hfc, underdrive crank pulley, 18" BBS CH., K04, MTM stg 2, 415cc injectors.
    Sep 23 2021
    Las Vegas
    Ok so I figured out which wires go to the Ecm, is there power there all the time or only at cold start?
    Senior Member Three Rings Ryanhouck9's Avatar
    Apr 10 2022
    X3 m40i
    Quote Originally Posted by Fiction1990 View Post
    Did you figure this out? I have the no activity detected code for both downstream sensors after installing high flow cars too, back to stock downpipes with the same issue
