    Junior Member One Ring
    Sep 06 2022
    South Africa
    B8.5 S4 DRL are yellow - how to fix?
    Hi all,
    Noticed on my 2013 S4, that both headlights DRLs are yellow. Right at the start of the strip is a tiny bit of white; but the rest of the strip is yellow.
    Is this an issue that can be fixed without replacing the whole headlight?
    Sep 06 2022
    South Africa
    Quote Originally Posted by whitshrill View Post
    Hi all,
    Actually, looking at them more closely, they seem to be OK - slight yellow closer to the grill.I'll just live with it
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    There’s a guy who put out a replacement set of leds.
    Active Member One Ring MFCR's Avatar
    Jun 10 2022
    Dubai
    As yours became yellowish due to the extensive UV impact through the years, you can buy a replacement DRL guides off aliexpress.
    Not an easy job – you would need a heatgun, butyl sealant and some skills to reassemble the headlights, but it is certainly doable.
    Good luck!
    https://www.aliexpress.com/item/1005...280204794%21sh
    Sep 06 2022
    South Africa
    Quote Originally Posted by MFCR View Post
    Good luck!
    Luckily mine are no where near that yellow, I see in the pics. I do have protective film on the headlights as well, that seems a bit yellow ish too. So I will try replace the film, first this week. If that does not improve it might, I'll live with it until I can buy new headlights. Not up for that DIY - seen too many YouTube videos on it, to know, that is not a job for me lol.
