Hello everyone, all day today I’ve been watching forms and videos and going through the process of taking off my valve cover to change the gasket and all the timing seals
I have got the gasket off, but I am confused on how to remove the fuel and vacuum pump the proper way to get the new gasket on before I get the valve cover back together.
I also want to know this, I’ve heard a lot of people saying that I need to detension the timing so the cams don’t pop up.
I did not do this because I heard some people say it won’t, and my cams stayed in perfect with the slots. Although I am worried, and want to make sure that while the timing chain is still on and tensioned thst I should not have any issues with timing after this.
The cams look to be in the same place as when I took the gasket off, but just want to rule out that possibility.
I just want to do the fuel pump correctly because of course, it never fails that something will break, and while taking off my Pcv unit the exhaust oil water separator pipe thst was connected had the nossle into the pcv break off. Gotta wait till Wednesday to put my car all the way back together for a $90 piece of plastic, where the stealer ship wanted $240 lol
Last thing, I’m currently in the process of cleaning the valve cover old gasket off, and the dealer told me to use a razer which I have, but I am worried because a few micro pieces of the old gasket fell into the engine. I assume since it’s just a very very small piece of rubber nothing will happen, but I am thinking about draining the oil to be safe.
I want to know if there’s an easier way to block the internal engine area and the cams with something so I do not drop any more flakes of rubber in there.
