Results 1 to 14 of 14
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    If you have a q5 and you lice in the north you need to see this
    It looks like a little bit but it's all rusted under the factory sealant, i have to rip out all the sealant, sandblast, epoxy primer , put new sealant then i'll shoot some wax rustproof...
    The factory sealant is a bitch to take out...
    I think this is a defect, for some reason water infiltrates from the top, goes between the seams and can't get out, rusts under the sealant, so it may look like it's nothing there.....
    Attachment 286034Attachment 286035Attachment 286036IMG_20221022_170859.jpgIMG_20221022_155115.jpgIMG_20221022_155111.jpgIMG_20221022_155103.jpgIMG_20221022_155054.jpgIMG_20221022_155044.jpg
    Sent from my LYA-L0C using Audizine Forum mobile app
    BetaAlphaTau member #19
    Apr 13 2009
    NS
    Where are the pictures from on the vehicle ?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Is this the upper portion of the front wheel well?
    Is this a "flood" car?
    Oct 20 2021
    Bulgaria
    Well my q5 is from Nova Scotia and the rear has a lot of rust. But on the Front it is not that bad.
    Sep 24 2014
    Central NJ
    NikolaZ: You have rust on the body? or the rear subframe?
    I have not seen any body shell rust, but plenty of surface rust on the rear subframe.
    Why Audi uses galvanized steel or aluminum everywhere EXCEPT for the rear subframe (black painted mild steel) has always puzzled me.
    Oct 20 2021
    Bulgaria
    On the Rear subframe only.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Looks like what you would normally see on a pickup truck on the Northeast. You may want to consider POR15 as well. Q5's particularly do come with surface rust on the rear subframe. The sooner you can blast the rust off, the better. I wouldn't wait. If you are in the process of replacing rear sway bar, that might be the right time to tackle this. Your rust though is on a whole 'nother level.
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Feb 27 2011
    Winnipeg
    Is that the seam sealer in the front behind the front strut mount? I noticed mine doing that on the passenger size I soaked it down in aviation grade corrosion inhibitor last fall.
    Nov 24 2004
    MOntreal
    Quote Originally Posted by seanf86 View Post
    Yes it is, mine was visible just a bit, when i ripped it out found all that, water infiltrates from the top and it is trapped under the sealant, its a factory defect in my opinion
    Nov 24 2004
    MOntreal
    Quote Originally Posted by S4'ed View Post
    Not a flood car, yes its the front where the shock mounts
    Nov 24 2004
    MOntreal
    I cleaned it with sandblast, used epoxy primer, put new sealent..i'll have some pictures tomorrow
    Nov 24 2004
    MOntreal
    This is the rear, under the inner fender near the rear door, same thing, water and salt puddles in that area goes under the sealant and rusts, removed the sealant, sandblast, epoxy primer, new sealant, asphalt undercoat, i hope that should do it...i shaped the sealant at an angle so that the water runs out instead of staying thereIMG_20220819_155506.jpg
    Nov 24 2004
    MOntreal
    At the same time did the brakes, pulley, new tensioners and idlers, honey comb grill...etcIMG_20221002_180208.jpgIMG_20221031_160829.jpgIMG_20221029_164408.jpgIMG_20221002_180158.jpg
    Nov 24 2004
    MOntreal
