The time has come.
I'm the only owner of this car. Bought it originally in 2006.
$6000 for whole car.
Engine is blown. Needs whole new bottom end. Most other mods listed below. Still more that I didn't list or forgot to mention.
2006 Audi A4 2.0T FWD
Recaro seats
Red Carbon fiber interior trim
Carbon fiber exterior parts
Borg Warner EFR 7163 Turbo
TurboSmart Comp Gate 40 38mm Wastegate
Clutchmasters FX350 Flywheel and clutch
Integrated Engineering Direct 4 port Methanol injection
APR HPFP
TFSI Cam Roller Conversion
Upgraded LPFP – DW450
PRV - 175 bar
RS4 injectors
PM4 Torqbyte Fuel Controller
Treadstone TR18T intercooler
Integrated Engineering cam shaft gear
Balance shafts deleted
RamAir Cold Air intake
Mishimoto oil catch can
Intake manifold flaps delete
Ferrea valves intake valves, Supertech exhaust valves
Integrated Engineering valve springs and retainers and valve stem seals
2.5 inch exhaust
ARP head studs, main studs, flywheel bolts, and cam girdle studs
GFB DV+
Coilovers
ECS Billet frame inserts
End links
Sway bar
Upper control arms
Lower control arm bushings
Snub mount
Trans mount
Short shifterAttachment 286022Attachment 286021Attachment 286023PXL_20221022_193049898.jpgPXL_20221022_193126411~2.jpgPXL_20221022_220517054.jpgPXL_20221022_220445700.jpg
Sent from my Pixel 7 Pro using Audizine Forum mobile app
