Results 1 to 4 of 4
    Junior Member One Ring
    Nov 01 2021
    Rome Italy
    Which oil for Stage2
    Which oil is better to use with stage2?
    5-30 , 5-40 or 0-40?
    The Last is 511 spec
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Just about any full synthetic oil is good. You will hear various personal opinions. Some people swears up and down with Amsoli, others with liquy Molly, Castrol, royal purple, Mobil one.. etc. Stock, stage 1 or stage 2 wouldn't make much difference in my opinion, as long as you make your oil changes intervals with 100% full sync you will be OK.
    There are tons of lab tested oil comparos done over the years, I have seen a royal Purple one once and it was the winner. poeple here says that Amsoil drops temps by 2--30 degrees. I only done Castrol and recently the dealer recommends Mobil 1.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Liquimoly Molygen 0w-40 for me
    Nov 06 2017
    Vancouver
    Just use an approved oil. It’s honestly not that important, one is not going to mega-outperform another. Even the grade is largely irrelevant because all the 502/504/511 specs require minimum HTHS which falls into either thick 30 or thin 40.
