I am looking for feedback and advice for a true flex fuel option on my RS3 and I am looking for info here because FB sucks and I am old school and still prefer forums!!
I have a 2019 RS3 with some basic mods Uni S1+ tune and S2 TCU tune along with midpipes, CTS 4" turbo inlet and intake pipe running though the stock air box and even that factory paper element. I also have a P3 gauge with a ECA installed With as little as my car has done it does run pretty well. Last year after completing the mods It went 10.88@128 on a draggy pull running 78% E85 and I have made a few 10.90-11.0 passes all at 128mph. On S1+ 93 the car runs 11.20s @122 all these runs are last fall in good air. TBH I am perfectly happy with the level of performance I get from the car on E85 and would like to run the car on a flex fuel program all the time without having to re-flash the ECU or manually change fuel maps or tunes.
I am not sure how the DS1 flex fuel works? Do you just have the ability to manually change the fuel map to account for the change in ethanol content or does the ECU automatically scale the fuel MAP and timing based on ethanol content? I went looking and I did not find out much about how it actually works? I know you have to wire a ECA sensor into the ECU pin with a 3k resistor which is not a big deal but curious as to how well it works just driving.
I mostly just drive this car and have other hot rods that are considerably faster than my RS3 especially in a drag race and are also true flex fuel cars. I only drive the RS3 in the warmer months and while I have 5 E85 gas stations within just a couple mile of my house there are none in areas I frequently travel to with the car. So to take the car to our summer home I have to swap back to 93 and then swap back to E when I got home, kinda of a PIA.
I have not done much with the car this year other than drive it and left it on 93 all year. Other than hurting a Hellcat and Corvette owners feelings at a couple of stop light encounters I have not raced the car at all this year. I am getting ready to put it away for the winter and swapped the factory tune back in to take it in to the dealer for the recall and a coolant leak it developed with only 11k miles on the car. I am considering making the change to the DS1 over the winter but want to be able to keep the same performance I have with the Uni S1+ E85 tune and the ability to just put what ever gas I can get at the pump without having to mess with fuel maps or re flashing the ECU? I also want to keep my P3 gauge and ECA which is another issue with the DS1 I don't think you can split the signal?
Another issue I have with the DS1 is it seems to have a step learning curve. While I have a lot of experience with tuning and datalogging I just don't want to get into learning another software and computer platform when I have two other cars running two different systems already. I really just drive my RS3 and not looking to mod it much more than it is. If I were plannign to do the motor and upgrade the turbo fuel system etc I would go all in on the DS1 but I really want something that is PnP so to speak.
So since I wont see the car till April maybe I should wait for the Uni-corn Flex fuel option that has been several years in the making.......lol!!!
