Results 1 to 10 of 10
Thread: Wheel part
    Junior Member Two Rings
    Oct 20 2022
    Glasgow, Scotland
    Wheel part
    I know this is a daft question, but what's the part immediately outside the centre disc?
    All 4 of mine are perished and ideally would like to replace, or are they part of the actual wheel?
    Thank you
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Theyer center caps. Theyre exspensive to replace, about $50/ea. But ya can take them apart and paint/clear them. Wurth silver wheel paint is a perfect match.1025201937_HDR.jpg1019201353.jpg
    Sent from my LM-G710VM using Audizine Forum mobile app
    Oct 20 2022
    Glasgow, Scotland
    Ah they look fantastic! Can I remove them and still use the car? (Yes, I'm NOT a manly man and ask stupid questions about cars!)
    Thanks for your patience
    Oct 20 2022
    Glasgow, Scotland
    And did you just spray over the entire thing, audi rings and all?
    Nov 10 2018
    08 audi a4 cabriolet,'12 Prius, 87 Alfa Romeo Spider
    New york
    You insert a hook into the hole in the center cap where the rings are and pull smartly. There should be a hook packed with jack/tool kit in the trunk (boot). Jayz says you can separate the ring part from the rest of the part. I didn't know this, but if you can't, I'd mask that part off. The caps are just trim covering the lug bolts; will not affect driving
    Oct 20 2022
    Glasgow, Scotland
    Ok excellent, thank you
    And I appreciate the "trunk" translation for me, haha
    Oct 20 2022
    Glasgow, Scotland
    To my astonishment, the tool is there and caps cane off easily
    The bit of mine that's tarnished is the plastic disc bit, so won't even need sanded or primed, just resprayed and lacquered?
    Established Member Two Rings 007J's Avatar
    Jul 28 2021
    2006 A4 Quattro
    TN, USA
    I'd do a very light sanding to get the outer ring even and put painters tape all over the center to make sure there is no over spray. Would not risk the paint getting on the emblem unless Jayz says he did it that way.
    034 MS RSB & Adj Endlinks, Snub & Bracket, HD Tierods, Adj Front Crtl Arms, Dif inserts, HPFP
    CTS Turbo VC, CC, HFC, FMIC
    ECS Poly engine mounts, Turbo Inlet, Skid plate, Carbon Wing
    Motoza Stage 2 E85, Raceland Ultimo CO, SilverProject Adj Rears, PowerStop Z26 F&R, APR S3 Injectors & Coils, RS4 FPRV, R8 fuel module, GFB DV+, Custom CAI, Brisk plugs, TT DP, 6.6bar custom FF, Wasa FW BSD, Asanti Orion 19x8.5, Maxton Lip, LED Spec D HL, BFI Shifter, Hella Horns, Conti SportContact 6
    Jan 21 2018
    frackville, pa US
    Yes, as in my pic, everything comes off. Then sand, prime, paint, clear. Paint I mentioned matches perfect, and 2k clear for best results. Paint supplies will cost $50-$60, but will come out like new, for the cost of 1 new one. When paint dries, reinstall rings and trim rings. They have tabs ya push out from the back. Just be gentle, use a small pick or flathead.
    Oct 20 2022
    Glasgow, Scotland
    Top man, thank you
    Will post the results!
