Results 1 to 6 of 6
    Established Member Two Rings Eastcoastmod's Avatar
    Dec 09 2019
    04 B6 S4 Sedan 4.2 manual. 05 B6 S4 CABRIO TIP
    Nova Scotia Canada
    Where do I unplug the passenger side cam solenoid?
    Been searching but can't find the answer.
    I have severe rough idle. fouling plugs passenger side only.
    I read somewhere I can unplug the cam solenoid and should get smoother idle if that's the issue.
    Where exactly do I unplug it?
    Would like to do that before tearing it apart.
    Thanks in advance.
    my first Audi 05 B6 S4 4.2 TripTronic Cabio less than 55000 miles
    Dec 09 2019
    Nova Scotia Canada
    Will likely try hitting the solenoid with 12v to see if it's stuck as well.
    Just want to be sure I use the correct plug :)
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    At the firewall you find a bracket with some connectors, follow the one who is going down to the solenoid. Be sure you have the good one, lambda is there too.
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Dec 09 2019
    Nova Scotia Canada
    that's been my issue. I can't follow without unclipping everything.
    All my wires are ziptied like crazy. previous owner.
    Pretty sure Lamda is larger green one.
    I'm hoping it's the small black one on the right as It looks right when I see images of the engine out and the plug hanging but don't want to fry anything by being impatient. :)
    Dec 09 2019
    Nova Scotia Canada
    18guage leads did squat.
    Was that big enough?
    Not hearing anything.
    Seeing small arc as I release the leads.
    Does polarity matter?
    Tried both ways.
    Dec 12 2020
    Europe (NL)
    Quote Originally Posted by Eastcoastmod View Post
    Yes it should be, I used dmm leads too.
    It starts with a light bump sound, after 20-30 times it's more noticeable
    Tried both ways.
    No
