Results 1 to 11 of 11
    Sep 28 2022
    Minnesota
    Advice on winter tires and wheel set up
    Hello everyone,
    I realize this has probably been discussed a number of times now but it seems like a lot of past discussion has been on the last gen RS3. So having said that, on the 2023 8Y RS3, is it cool if I use a square set up running winter tires? I have existing winter tires that are P235/40R19 and would just need a buy a new set of wheels.
    Nov 06 2017
    Vancouver
    You can square up the tires no problem but it is likely you will need to buy two pairs of wheels, with different offsets, and then not rotate them.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by rs3_guy View Post
    Hello everyone,
    235/40/19 wont work, the overall diameter is to large of change from stock, you want to stay within 3% to keep all the electronics systems happy. With a 19x9 and 19x8 the recommended "square" tire size that will fit both wheels is a 245/35. The 245/35 will work but probably will be really stretched on the front 9" wide wheel, and for winter you obviously want the biggest sidewall you can get. That being said the Michelin Pilot Aplin Sport in 245/35/19 is very wide for its size so might look "ok" on the front 9" wide wheel?
    Stage 1 more than you RS3
    Sep 28 2022
    Minnesota
    Quote Originally Posted by o1turbo30v View Post
    But if I get aftermarket wheels then that should negate the problem, right? Or will different wheels trigger some electrical sensors?!
    Nov 06 2017
    Vancouver
    235/40R19 are a bit tall but probably ok if the car isn’t lowered. If you haven’t bought tires yet I’d probably go with 245/40R18 on 8.5” wheels. But if you have the 235/40R19’s already, they will work.
    Nov 11 2021
    Atlanta, GA
    For my TTRS, i'm running 235/35R19's on a 19x9" wheel lol. No problems whatsoever with the electronics or otherwise. 25.5" tall vs 26.1" stock. Nice boost in acceleration and handling and better ride quality with the superlight 19x9's from unsprung weight loss. I wouldnt go smaller, the tires are def stretched a bit but car runs and handles beautifully.
    Nov 25 2013
    Ottawa
    Audi fitment is 235/35R19 square. The front wheel is ET25, while the rear is ET46. Not a lot of wheels will clear the front caliper.
    On the 8V I fitted 225/40R19 and there was just enough room. Since the 8Y has wider 265 tires (255 on 8V) I would expect that a 235/40R19 would fit, but cannot confirm.
    Nov 06 2017
    Vancouver
    Quote Originally Posted by steve111b View Post
    The 8Y would not be 235/35 square, it would be 245/35. So 235/40 is not as much of a fitment issue as it would be on the 8V.
    Sep 01 2012
    Edmonton
    I'm currently running the PA4's in 245 35 19 and there is rubbing on the drivers side wheel cowling. Just a heads up. 19x8.5 ET 43 square set up.
    Sent from my SM-G970W using Audizine Forum mobile app
    2018 RS3 Panther Black
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by WAF View Post
    That would make sense on the 8V, OP has an 8Y that has more generous fenders
    Sep 01 2012
    Edmonton
    Drinking and posting has its downfalls..... my bad.
