Results 1 to 7 of 7
    Nov 11 2021
    Atlanta, GA
    Mechatronic replacement required per Audi after 200 launch control done?
    Found this in a different forum:
    "The 2018 TT RS Launch Control is limited to 200 launches. After that the mechatronic module in the transmission needs to be replaced to get another 200 launches. Audi says they will replace it as many times as necessary as long as it is under warranty. After that it is a $2k expense. I have had mine replaced twice. Is this going to be the same for the 2019? Could not believe it when they told me, the dealer said they had no idea about this that Audi Germany told them after my second replacement."
    Does anyone know if there is a computer code that will trigger after 200 launches/etc or another way you would know what the counter is, or if this is not even accurate?
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    A TCU tune can increase the launch counter allotment.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by doughboy17 View Post
    I'm staying stock TCU and ECU tune so just curious for us rare few. :)
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Pretty sure you can get the launch count through vagcom/vcds.
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by mtwallace85 View Post
    Nice i will see if i can track that down. Anywhere that documents that it gets replaced after 200 launches?
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    sure, but only on April 1st
    Quote Originally Posted by TToysRuS View Post
    2020 TT- RS
    ex 2018 TTS
    Aug 11 2019
    Rome, Italy
    yes, you can, in 02 autotrans
    2020 TT- RS
    ex 2018 TTS
