Results 1 to 19 of 19
    Sep 01 2012
    Edmonton
    4" 034 turbo inlet install question
    Hello, Can anyone confirm that if installing a 034 4" turbo inlet pipe (2018 rs3) requires you to upgrade the waste gate line to the unitronic waste gate line upgrade kit? Or will the oem line fit? I've heard new wastegate line is required on 4" inlets and 3" inlets are compatible with the oem line. Thanks in advance.
    Sent from my SM-G970W using Audizine Forum mobile app
    2018 RS3 Panther Black
    Sep 27 2020
    Golf TDI
    San Diego
    Hmm. I'm emailing my 034 rep if it's required or not, or a good idea to do. I'll be installing their part soon.
    2019 TT RS - S2E85 034 Motorsport - If you're gonna go, you gotta whoa!
    Junior Member One Ring
    Oct 14 2021
    Gallatin, TN
    When I installed the 034 4" inlet I did replace the metal line that bolts to the inlet and just ran similar sized vacuum line over to the firewall and up around the inlet toward the fuel lines. Then ran it across under the engine cover and reconnected to where the metal line transitions to rubber. Essentially replaced one section of metal/rubber line with an all rubber single piece vacuum line that runs around a safer/cooler location.
    I did try to bend the metal OE vacuum line to try to make it work, but ended up too mangled to use and just looked bad.
    I'm not familiar with the Uni upgrade kit to know if it offers any other advantages. I only spent a few bucks on 3' of vacuum line and 2 screw clamps.
    Mar 09 2018
    2018 RS3
    I don't think it's necessary but with like most 4" inlets, you lose the hard line attachment point.
    Florett RS3+DS1+034TCU
    Jun 24 2018
    IL
    I did not upgrade my line and it runs fine. '18 RS3
    2018 RS3 Daytona Gray
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    With the 4” line it’s definitely necessary because the stock metal hardline is bent to fit fairly tightly around the stock elbow and it doesn’t fit around the bigger inlet.
    https://www.audizine.com/forum/showpost.php?p=14002286
    Sep 27 2020
    Golf TDI
    San Diego
    Can concur, 034 replied and said a custom waste gate line will be needed to work properly with the 4" elbow, needs to be routed above.
    What's diameter and general length of the silicone hose?
    Sep 01 2012
    Edmonton
    Quote Originally Posted by DrMerl View Post
    Thanks for conquering that. Sorry which silicone pipe are you referring to?
    Jul 11 2021
    Midwest
    I recently installed the 034 4" inlet. Prior to installation, I ordered in a Unitronic wastegate line upgrade ($38) because I'd been hearing how difficult it was to get the oem metal line to bend and fit around the larger 4" inlet. Anyway, the inlet installation was a piece of cake, As far as the wastegate line goes, I ended up not bothering to replace the entire oem line with the Unitronic upgrade. Instead, as 01CamaroSS did, I simply trimmed the Unitronic hose to size and replaced just the metal section of the oem line that connects to the inlet. That seemed the easiest way to do it.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Old thread, but no where in 034’s write does it say the line needs to be replaced or changed. Have they made changes?
    https://www.034motorsport.com/docs/0...structions.pdf
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Jun 24 2018
    IL
    Quote Originally Posted by CavEsk1337 View Post
    Glad this thread was resurrected.
    Update: My OEM wastegate ended up failing about 1 1/2 yrs ago. I upgraded to the Unitronic line and have had zero issues since.
    Jul 11 2021
    Midwest
    The issue is that the increased diameter/size of the 034 4" inlet, as compared to the OM inlet, makes it difficult for the oem wastegate line to stretch around the inlet to reach the wastgate. The oem line is composed of like an alternating series of metal and silicone tubing segments. There is a metal section of the line near the inlet that interferes with the line fully reaching the wastegate. The Unitronic replacement line is just a solid silicone hose with enough length to reach the wastegate. As I mentioned in my earlier post, I left the entire oem line in place, except for removing just the metal section near the inlet, and replacing that section with a piece of the Unitronic line long enough to reach the wastegate. That seemed the easiest way to do it, rather than yanking out the entirety of the oem line. the inside diameter of the Unitronic line fits up perfectly the metal sections of the oem line. Hope this helps!
    Oct 31 2014
    NH
    Quote Originally Posted by Hollingsworth View Post
    Good to know. It’s just strange that 034 does not mention this at all.
    Also, why is the Unitronic 4” inlet $200+ more than the 034 one. Seems a bit ridiculous.
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Yeah, it doesnt matter which 4" inlet you go with, you will want to replace the wastegate line from about cylinder 3 to the wastegate. Not sure why 034 doesnt supply you with the $2 hose? Even the basement bargain CTS kit comes with it.
    2024 RS3 Kemora Gray
    Sep 27 2020
    Golf TDI
    San Diego
    034 sent me a silicone hose from WG to the metal pipe across the head. I got an early production unit which had a casting defect, they sent a new one in a few days. It added a bit more to the mid-top on S2 E85 over the 3" 034 elbow. I also left the OEM piping, except for the hose, what is it about 10-12"? Works great so far, no problems with the hose getting close or touching heat items.
    Oct 31 2014
    NH
    Emailed 034 today and was told "We have not found the need to upgrade/change the wastegate line when using our inlet pipe. There should be no issues installing our upgraded inlet on your RS3."
    Looks like I'll just order the Unitronic line.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Oct 31 2014
    NH
    2014 Audi S4 - 6MT
    2000 Audi A4
    Jun 24 2018
    IL
    Quote Originally Posted by adam044 View Post
    I'd probably do it for piece of mind.
    Here is my OEM hose. Snagged a Uni line and have been good since.
    Mar 01 2013
    Atlanta, GA
    It is an internal diameter of 4mm. You can get the silicone line on Amazon for like $10
