Results 1 to 40 of 98
Threaded View
    Senior Member Three Rings Jimingle10's Avatar
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    MMI Updates & NAVI Updates
    I aquired the latest firmware and what I believe is the latest USA/NAR map updates for C7
    I'd be willing to put them on SD Cards and mail them to people if you cover the costs/shipping. Not sure where a good spot is to upload them for sharing as the map card is quite massive.
    HN+R_US_AU_K0942_3
    8R0060884JE NAR 6.24.0
    The MMI update goes quick but the map update took around 90 minutes. I left the car running for each update.
    ** You do need GREEN MENU enabled for the MMI Update ** --- VCDS required to enable that
    The map update should only be applied if you are on the latest MMI firmware
    I'd be happy to walk anyone through it
    Before update
    After update
