Results 1 to 15 of 15
Thread: Break in advice
    Senior Member Three Rings Dietbudda's Avatar
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Break in advice
    Hi, just had my Aluminum light weight fly and stage two clutch from AWE installed and as wondering about break in time. they we saying over 1000 miles with no boost. this seems a little long for break in on a clutch i've been told anywhere from 250 to 800 miles, how long you guys think?
    Also curious as to what you guys uggest as far as break in, from what i understand i'm not going to hit max power when out of boost no matter what the RPMS, i'm unlucky enough to live in a rather hilly area and need higer rpms to climb home, can i use a small amount of boost? i.e. 5 or below? As you know these 1.8t's have NO guts without boost.
    Thanks in advance guys.
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    You can use some boost, as long as you don't shift hard at all. I went 500 miles with 0-5psi, but you can't help that since the turbo spools there pretty quickly.
    2016 Audi S3
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    good that's kind of what i wanted to hear, i was driving it home trying to stay ot of boost and it's difficult to do that sometimes. Thank you.
    BTW how do you like the the up?
    B.A.T. coming soon...plus...
    Veteran Member Four Rings iowaboostin's Avatar
    Sep 17 2006
    Portland, OR
    As with all my new clutches on any car I've never gone over 4k RPM or ~7psi for 500 miles as well.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    AHHHH self restraint is going o be VERY difficult, but so fr i've put 100 on in 6 hours only accidenlty hitting high boost once.
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    if you go to the stock file you should have no problem since it's unlikely to make enough torque to glaze the clutch
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Feb 27 2005
    North Wales, PA
    hahaha well just think about the gas you are saving....kinda...
    well i guess not really since you will find every excuse to drive to rake in the miles. High way miles do not count as break in miles. haha
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Swapping in the stock ECU in tomorrow that should help, so the general consuse is 500 miles? coolness
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    i was easy on mine for about 750 miles. i think i hit high boost once, but it was after a few hundred miles
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Break in periods always depend on what is on the disk. Some need easy driving some need you to burn the top parts of the surface off and some(race clutch) need no break in at all.
    What was on your disk?
    BTW when they say "miles" they actually mean stop and go traffic type of miles where you use the clutch often. The other way to break in a clutch is to do some very short WOT runs at low rpms in 5th gear at low speeds on the fwy. This allows for heavy load and it is easier to watch the tach to make sure you lift as soon as you see the rpms jump faster then it should. This is exactly how I was able to break in my very first clutch in less then a week before hitting the track, that was back in 2001 being the first dbw B5 to need a upgraded clutch.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Not exactly sure what is on the clutch, this is the kit i bought
    http://www.awe-tuning.com/pages/shar...L=AWEClutchKit
    It feels REAL good though, and i'm real happy, just can't wait to give it a good caning
    Jul 07 2004
    socal
    It has Kevlar on it which will have a soft layer on the top which needs to heat up and burn off so the rest of it can set. This is exactly like the clutch I was able to break in in less then 1 week by doing the 5th gear pulls on the fwy at low speed.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Thanks mike, looks like i have alot of driving to do before Show and go then.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    i broke in my SouthBend DXD OFE SS (stage 4-ish) clutch over the course of a week. just normal stop and go driving with no WOT. i took detours every day through every stop sign filled subdivision i could. less than a week later i did a track day and it held perfectly well.
    Jim
    I Do Werk.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    now is there any special treatment for the aluminum flywheel? I've head they are a little tricky to set
