Results 41 to 80 of 91
Thread: Jackal Tune!!!
  1. #41
    Stage 2 Banner Advertiser Two Rings Matt@Jackal's Avatar
    Dec 27 2019
    Big Turbo B6 S4, Jackal NA B6 S4, Jackal SQ5, Jackal S3
    Carver, Ma
    Quote Originally Posted by Rilla View Post
    Throttle response has been addressed.
    No issues passing inspection in NY unless you opt for SAI delete which is not an official option yet.
    Definitely opt for the exhaust flaps open always in sport!
    It will pass NY, MA and CA inspection no problem
    And sport mode has the flaps open 100% as a standard! Comes on all the tunes.
    We offer a stock style throttle or an aggressive one. You can pick it when you select your tune on the tuning suite. And you are free to flash between tunes anytime
    Owner - Jackal Motorsports
    Industry Leading Audi Tuning
    http://www.jackalmotorsports.com
    [email protected]
    World record Built Big Turbo B6 S4
  2. #42
    Dec 05 2006
    So. Cal.
    Are you sure on that? California just instituted a new law regarding ECU's.
  3. #43
    Oct 11 2007
    Suburbia
    My car was a cali car that passed w/ the Jackal tune and catless DPs, but that was early 2023
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
  4. #44
    Jul 26 2014
    Upstate NY
    I still cannot decide whether to just do a cc (and maybe put some loctite around the flap screws) or do the cc + deflap + jackal tune. My concern is that if you look at the RS4 dyno graph on the jackal website, you can see that torque peaks at around 3800 RPMs, on the stock tune the peak occurs at much higher RPMs l (around 6000 from what I’ve seen on other dyno graphs) so you have to rev out the engine. I don’t doubt that the tune makes the car faster, but for those who have it, does it change the feel of the car, with more torque down low?
  5. #45
    On top of screws backing out, flaps can break, and with age when the screw are tighten with loc tite, could cause stress cracking through flap cycling, and a piece of flap breaks off. I don't know the real stats on this stuff, but even the .5% chance was enough for me to remove them all. We do have a replacement motor issue with these cars so not worth the risk for anyone to keep them in my opinion
    Someone else should answer to your torque peak questions, interested to know too...
  6. #46
    Jul 26 2014
    Upstate NY
    Quote Originally Posted by longlivenacars View Post
    Did you replace your IM flap arms with 034 billet aluminum arms to avoid any potential CEL with the deflap and future arm failure? Or did you keep the plastic ones? Thanks.
  7. #47
    Quote Originally Posted by DWRS4 View Post
    I did not replace with the 034 billet arms. I was able to borrow the 034 punch tool from a local owner who did install the arms. That car had 272,000KM at the time and had been de-flapped without a tune and running fine like that for about 100,000 KM (AND had JHM intake spacers). I don't have the spacers, and my car was fine without a tune, until these codes popped up a while later. Because they were a while later, I still don't think have anything to do with de-flap.
    When I did my de flap, upon reinstall, I only had my cat delete codes, which were there before. In the past year at some point, I got a code that seems to pertain to the flap sensors. My car is currently apart, but the defective one is the passenger side (IIRC my codes) for me, and can be changed in service position without IM removal. The flap sensor at the back, driver side requires manifold off. I do remember reading posts about those arms breaking for some, but my guess is that people rough tumble with them on delicate IM removal and positioning on a work bench and break them like that. For the function they have, they seem strong and well built enough. Plus, IIRC they fit into some little plastic ball and sockets joints so the actual arm I don't think would cause an issue. << This is still just speculation though. One of my arms did have some play, you will probably get the work done on your car before I make a IM video part 2, but I'll link my YouTube and you can follow to see what happens with my car. My codes could be for the flap sensor or a cracked vacuum line under the IM. I doubt it's the slightly loose arm mechanism, but not ruling that out.
    https://www.youtube.com/watch?v=EIs6VPbG5TQ
    Edit: I can't recall if that person had a JHM tune with the install of intake spacers. He told me the info that it would run fine with de flap and no tune was what I based my attempt on. Reliable source as he worked as a pro euro car mechanic. Another local rs4 mechanic that sees a few of these also told me it would run fine with no tune and de flap, and that the car would just have some hesitation on cold starts sometimes for a very short duration
  8. #48
    Jul 26 2014
    Upstate NY
    Thanks! BTW I’ve seen your videos before, well done.
  9. #49
    Redirecting thread for someone to reply to this:
  10. #50
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by WinterRunner View Post
    The Kalifornia Law went into effect on July 19th 2021 so the previous owner probably got in under the wire.
    Here's a good reminder to anyone running a tuned car out in California: As of today, July 19, the state's notoriously strict smog testing will automatically fail any car when it detects modified software onboard, aka, a tuned ECU. Drivers can't register a car in the state unless it's passed a smog check.Jul 19, 2021
  11. #51
    Oct 11 2007
    Suburbia
    I want to add that I just flashed the latest file today and it really cleaned up first and second gear throttle response and feels fantastic!!
  12. #52
    Jul 26 2014
    Upstate NY
    Could you share whether you picked the “aggressive” throttle map or the “close to stock” throttle map?
  13. #53
    Oct 11 2007
    Suburbia
    I picked the not-stock throttle map, 93, no flaps.
  14. #54
    Dec 27 2019
    Carver, Ma
    That is a deflapped car, with an unknown last carbon clean
    [email protected]
  15. #55
    Veteran Member Three Rings ginch's Avatar
    Jun 30 2011
    calgary, alberta
    Quote Originally Posted by TheRealJackalS4 View Post
    Might want to update that with a clean running RS4.
    I'm super happy with the tune. Car feels much more eager and responsive!
    2008 Avus silver RS4
    1996 993 C4S
    2017 Tacoma TRD Sport, Quadcab shorty, 6 speed, Wife's daily!
    Gone
    2016 Reflex silver Golf R, 6 speed
    2008 Phantom black RS4
    B7 S4 Avant
    1993 964 C2
    2004 Reflex silver .:R32
  16. #56
    Off topic on this thread, but was discussed here, so posting here. Edit to my 4-29-2023 post. Looked at my car today, and it isn't ball and socket, it's more of a pin (looks like a dowel pin, don't know technical term for it) that is held in by what seems to be integrated, plastic retainer clip, onto a circular ended pin. Some wobble in mechanism on mine but will see in future if it is an issue. The play on mine could also be at the other end of the arm which is not visible in the pic, but been a long time since I've seen under manifold. Note that access for this pic was done on an rs4 that is currently in service position
  17. #57
    Oct 03 2011
    Buffalo
    I was just saying we need the OBD Readiness addressed for cold start/ SAI delete
    2008 PB Ti RS4, Jackal tune, Bilstein PSS9, Scorpion axle back, GruppeM
  18. #58
    Dec 27 2019
    Carver, Ma
    It is updated in the most recent revision
    [email protected]
  19. #59
    Oct 11 2007
    Suburbia
    So the stock throttle is more or less aggressive than the aggressive one? I currently have the "aggressive" one on and it seems to have smoothed out delivery, not made it harder to modulate. Will the stock setting be even smoother? I always thought the touchiness was due to the OEM self adjusting pressure plate.
  20. #60
    Dec 27 2019
    Carver, Ma
    Yep! The “stock throttle” map is just that, stock throttle parameters. Sport will be a little touchier like factory. Since that’s all it does. Sport also keeps the exhaust flaps open 100% of the time.
    The normal files that don’t say stock throttle are a more aggressive, enthusiast style map
    Both have the same overall power
    [email protected]
  21. #61
    Junior Member Two Rings Legless's Avatar
    Dec 17 2012
    B7 RS4 Phantom Black Ti - C8 A6 Allroad Nogaro Blue
    MA
    Got in for a last second flash today and really enjoyed it so far!
    Power feels so good in the low end and its really consistent in the mid to upper range, that new redline is fun too. Gonna try out aggressive throttle map and possibly E30 tune.
    Cheers!
  22. #62
    Jun 30 2011
    calgary, alberta
    Whats the new redline?
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
  23. #63
    Dec 27 2019
    Carver, Ma
    Quote Originally Posted by ginch View Post
    8500
    [email protected]
  24. #64
    Feb 27 2010
    2004 S4, 1995 S6, 1985 190E 2.3-16V
    milwaukee wisconsin 53201
    Wanted to drop a line to say thank you to Jackal for working with my shop recently to really improve the drivability of my RS4 cab.....the revisions have made the car a daily driver for my wife and now we never hesitate to drive it anywhere....I really appreciate a supplier that supports the product so well after the sale. I'm a fan and will look to add more Jackal to all my cars.
  25. #65
    Jul 26 2014
    Upstate NY
    I had my car deflapped and Jackal tuned a couple of months ago. Love it so far. It’s smooth and definitely feels like more power (I picked the stock throttle mapping and did a carbon clean at the same time so it’s not just the tune). Only downside is the SAI is now more aggressive during cold start ups: the car revs to about 2000rpms and feels just slightly rough—only for the first minute though and then it’s super smooth when the SAI process is complete or I start driving. I have only driven it a handful of times but so far so good.
  26. #66
    Oct 03 2011
    Buffalo
    Mine stumbles and misfires during SAI. Would be great to have SAI disabled with emissions readiness
  27. #67
    Jan 22 2019
    Philadelphia, PA
    Are you saying it has issues WITH the tune?
    07 RS4 Mugello Blue - Billstein B14 Coils/GMG WC Exhaust/JHM SS + BFI Weighted Knob/LED tail lights/Enkei RS05RR 19x9.5 et25 wheels
  28. #68
    Oct 03 2011
    Buffalo
    Quote Originally Posted by philbegas View Post
    Yes both with and without, ever since my flaps were taken out
  29. #69
    Oct 11 2007
    Suburbia
    My starts seem a little weird, but no mis-steps so to speak, just not a "dope" cold start like my R8 and even my 1.8T b5 have. When moving it's flawless and I find the drivability is quite good.
  30. #70
    Dec 27 2019
    Carver, Ma
    Just shoot us an email, maybe we can have you log the cold start for us and see what’s going on
    [email protected]
  31. #71
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Flashed the jackal tune today. They were really great to work with and made the process easy even with some laptop issues. Protip dont use a windows 7 laptop with their software.
    The stock throttle map is nice for drivability in 1st gear compared to my previous tune. I havent had a chance to rip through a few gears yet, but will report back once I do.
    Does anyone use the pop&bang option on their RS4? Would love to hear what thats like.
  32. #72
    Jun 25 2009
    SC
    Butt dyno says the car definitely netted some torques from the jackal tune :)
  33. #73
    Dec 27 2019
    Carver, Ma
    Glad to hear
    [email protected]
  34. #74
    Oct 11 2007
    Suburbia
    Is it normal to have slight fluctuations in the rpms at idle, like 30-40 or so? just moves around 800 a little, nothing startling.
  35. #75
    Dec 27 2019
    Carver, Ma
    Is the AC on at all?
    [email protected]
  36. #76
    Dec 27 2019
    Carver, Ma
    Alright, everyone that is on a jackal tune, there is an update on the server for everyone to log in and flash for free!
    [email protected]
  37. #77
    Mar 16 2023
    WV
    Any details on the update? I reflashed and I'm really loving it.
    - 2008 Audi RS4 Imola Yellow: JHM, GruppeM, KW
    - 2008 Lexus IS-F Ultrasonic Blue
    - 2006 Evolution IX Rally Red
  38. #78
    Veteran Member Four Rings Gewaltakt's Avatar
    Nov 01 2007
    06’ B7 RS4 Avant; Defender 110 safari truck
    Stuttgart
    Quote Originally Posted by Matt@Jackal View Post
    [/url]
    2nd this one, any insights on what the updates are?
  39. #79
    Oct 11 2007
    Suburbia
    It got rid of the throttle maps, and now relies on the S button, not sure what else but works well, flashed it right before a long cruise.
  40. #80
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    Well damn, was hoping to play with the different throttle maps after I ordered it...o'well.
