Results 1 to 10 of 10
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    EA839 SQ5 Torque Spec Compilation Wiki
    Since the service manual pdf's can be a nightmare to search through for simple things like torque specs, I started compiling the more commonly used torque specs into one spreadsheet for my own reference so I don't have to dig through a folder of dozens of several-hundred-page pdf's.
    Figured I'd share it with you guys. I'm just starting, and adding things as I need them. So if there's anything you need just reply below and I'll add it.
    I'm keeping it mostly EA839-centric, but all the chassis stuff is relevant for Q5's too.
    Link to the Google sheet
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Nice, thanks.
    iain
    Senior Member Two Rings robb1887's Avatar
    Apr 24 2021
    Virginia
    Spark plugs?
    18 SQ5 Prestige
    EPL, ForgedOne, CETE
    Build Thread
    Mar 25 2015
    Placer County
    Quote Originally Posted by robb1887 View Post
    Spark plugs?
    Added.
    Ignition coil bolt - 9nm(80in./lbs) | Spark plug - 23nm(17ft/lbs)
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Apr 24 2021
    Virginia
    Thanks.
    Internet didnt provide any good info what I did my own so they are a little overcooked at 30, but they didnt rip out threads yet, and the crush washers are going to uncrush so that's a future robb's problem
    18 SQ5 Prestige
    Build Thread
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    Front upper control arms to the body of the car?
    Mar 25 2015
    Placer County
    Quote Originally Posted by JonnyBravo! View Post
    Added. 37ft/lbs + 90
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Oct 26 2014
    California
    Quote Originally Posted by Gunnarrrrr View Post
    Thanks, bud. Now I know I probably overtightened them a bit. That probably explains the creaks.
    Mar 25 2015
    Placer County
    as per the shop manual I pulled these from, and just common knowledge, any control arm attachment point that has a bushing in it should only be torqued under load. wether that means using an alignment rack, rhino ramps, or just a jack under the lower control arm, whatever you gotta do. If you don’t, creaks are guaranteed.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Oct 26 2014
    California
    I did jack up under the control arm, but I'm pretty certain I overtightened everything. I'll have to double check and retorque with the correct specs. Thanks again.
