Results 1 to 3 of 3
Hybrid View
    Junior Member Two Rings
    Jun 07 2015
    RS7 Wheel option question
    Figured I would ask as maybe someone has ran into this before. Currently had this happen on more then one used rs7 prior. But now again on an rs7 that the last owner purchased cpo that im very interested in . I found the wheels on the build sheet/window sticker dont match what's on the car. Still oem, but another style or totally different color . Not a deal breaker persay, but I try to be as ocd as possible not to miss stuff . Always try to check if anything was modified that you don't want lol . Note all else checks out with said car.
    Guessing the dealer swapping for take off's - if one or 2 is damaged upon trade in is a possibility. Or old owner traded back in with winter wheels or vise versa. Maybe i'm getting to picky but any insight is appreciated .
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Model year? What's on the window sticker? Picture of what's on the car?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Jun 07 2015
    2014 , i'll have to upload some dealer hasn't posted pics yet . I'm guessing it could be a case of a 2nd set etc. Just odd happened a few times. Probably happens all the time .
