Results 1 to 13 of 13
    Junior Member One Ring
    Aug 16 2022
    Idaho
    I’m stumped 2004 Audi allroad 2.7t just shutting off.
    So I’m new here and I recently bought a 2004 Audi allroad 2.7t I love this car, but I have a major problem. I can drive it around town and it does fine, I take it on longer trips and the car just stalls like someone took the key and shut it off. I have replaced the timing belt, the water pump the ac pump, both cam shaft sensors the speed sensor. I am at a loss I have ptsd from driving this car not knowing when it’s just going to shut off. Other then just shutting off the car seems to run just fine. Any help is greatly appreciated.
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    ignition switch?
    any codes?
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    When you say speed sensor, which one are you talking about? Where is it located? My thought is the crank position sensor.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Quote Originally Posted by Kendra79 View Post
    ...I take it on longer trips and the car just stalls like someone took the key and shut it off...
    What happens when you try to restart the engine?
    May 20 2010
    Does it do this while stopped? Or while you're driving? My allroad had a bad battery and on the way to/from getting a new one (on the highway), it was literally shutting off and the engine rotation was turning it back on while I was driving on the highway.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 24 2010
    Paramus,NJ USA
    Wrong forum/section.
    Ziddy Autowerks
    Aug 16 2022
    Idaho
    I’m not a real car girl, I did replace the crank position sensor, I thought it was called the speed sensor. Thank you
    Aug 16 2022
    Idaho
    Sorry where should I post this?
    Aug 16 2022
    Idaho
    When I let the car sit for a bit 30 minutes or so it starts back up and seems to run fine. There are no codes. It’s while I’m driving. I’m sorry I am new to the page and am trying to figure it out. If I am posting in the wrong spot please let me know where I should be posting. Thank you.
    May 09 2012
    Virginia
    Post in the C4/C5 A6/allroad forum. I’m also thinking the coolant temp sensor in the hard pipe in the back of the engine as well as fuel pump. It would be helpful if you can scan the car.
    And welcome! C5 allroad is a great platform!
    Aug 16 2022
    Idaho
    Thank you.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by jbain2 View Post
    Why are you lying to her??? C5 allroad is the biggest money pit i've ever seen. Tons of issues. Between air springs failing, air compressors failing and issue with the 2.7T I would say run the other way. Sorry my honest opinion is that allroad will leave you broke and unsatisfied take it from someone whos been turning the wrench on these cars for some time. The most common cause of your issue in those cars has always been the ecm. Ask anyone who owns a b5 s4,c5 a6 or c5 allroad. Ideally you want to scan it for codes but I would not be surprised if the ECM is your issue as the issue occurs during driving and then after a short cool down cycle all is well again. Best of luck you've been warned.
    Ziddy Autowerks
    May 20 2010
    I don't recall any of the coolant sensors preventing my car from turning on; that said, I didn't have any sort of temperature reading from one of them, but the car would run/drive fine.
    The most common cause of your issue in those cars has always been the ecm. Ask anyone who owns a b5 s4,c5 a5 ora c5 allroad.
    Never had an ECM issue with mine ¯\_(ツ)_/¯
