Hoping I can make some headway here on some annoyance issues I'd have with my SQ5 since purchase. Have tried to chase these down for the better part of a month, to no avail. Have looked as much as possible online for any assistance and unfortunately there is nothing that has directly helped me with these faults.
For starters, the when turning on the car it immediately throws dashboard errors for the parking brake and ESC modules. When looking further I have uncovered the following codes:
Brake:
Fault 03265, Suspension Sensors Data Bus (No Signal/Communication)
Fault 00493, ESP-Sensor Unit (No signal/Communication)
Parking Brake:
Fault U111300, Internal Fault 185
Fault U111300, Internal Fault 138
I've looked online at the TSB for the wiring harness from the engine bay module through the fender/wing and into the cabin near the driver's A-pillar. No fraying or damage to report. Checked both at the module, throughout the fender, and into the body behind the washer fluid tank. Have purchased two spare G419 sensors to try and swap. Verified that there is a good ground and voltage for the ESP sensor from the harness. None of the sensors (original, coded/swapped) are showing any consistent readings in both live readings 005 and 010 in OBD 11. Showing 0 for G200 and G202 (005), and a static .97 for G201 (010).
For the Parking Brake, I am showing an inclination of 137 in Live Data. This is static and does not change. My assumption is that both Parking Brake faults are a result of the Brake module faults. I've looked through a majority of the readiness readings for the Parking Brake module and everything seems good.
I was searching through long coding and noticed that my dashboard is coded for air suspension. However, being a B8, these cars did not come with air suspension from the factory. I tried to revert to "inactive" when long coding, however, a code is thrown inside the Dashboard OBD11 module stating that is incorrectly coded when disabling air suspension. No, I did not adjust this myself, and no, it does not affect the any readings from the YAW rate sensor.
My thought process is as follows: If I can consistently get a CAN reading for the G200/202 for rotation, I can then use Basic Settings 069 to adapt whichever YAW rate sensor I please to the car. However, I cannot seem to get any sort of reading from any of the three sensors. I'm certainly at a loss here and would rather put the work in to resolve than drop it off at the dealer ship and get taken for a ride financially.
So where do I go from here? My assumption is that there should be a CAN reading coming from the G419 sensor, but that there may be a wiring issue, fuse, or something that is disrupting it from being read into the CAN system and to/through the live data for the network. If there is a reading from the ESP sensor and that feeds into the Suspension Sensors Data Bus, but is not being read correct, this would make sense. However, I cannot determine where to look physically in reference to the Suspension Sensors Data Bus.
Thanks everyone in advance for your help.
