Results 1 to 25 of 25
    Mar 03 2004
    2014 Allroad, 98 A4 2.8, 00 S4, 03 3.0L A4
    Chelsea, MI
    Replacing my Reverse Light Bulb
    Have a 2018 Q5, and the reverse light is out. Looked at Y-Tube to see how to replace - pop the cover off and sue a phillips screwdriver to remove screw. The problem is that I don't see the screw at all.
    What am I missing here? There is no screw. Do I have to pull the whole bumper to get to a light bulb?
    Thanks for any help
    Senior Member Three Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    Its' way up there.
    Hit me up on IG and I'll send you the steps.
    2021 SQ5 Daytona Gray | Instagram: @raudi_sq5
    Jul 14 2009
    Pasadena
    Quote Originally Posted by Kurt Koseck View Post
    Thanks for any help
    yea way up there at an angle. can be a pain to get to. while you are there you should upgrade to LED. I have had these for over two years with no issues. https://amzn.to/3JYQLff
    IG: @matthewee
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    I’ve posted this before. It’s a simple job, but can be finicky if you haven’t done it before. Also, the B8’s uses a Philips, but the B9 is a torx.
    2020 SQ5 | Glacier White Metallic
    BC Forged TD03 | CETE Lowering Module | Forge DV
    034 Transmission Insert | CTS Turbo Inlet
    AWE Coldfront | RocEuro Intake | 034 Strut brace
    IG: chrisssgreenwood
    Stage 2 Banner Advertiser Four Rings Miranda@Nemesis's Avatar
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    Quote Originally Posted by Chris.green View Post
    Bless. I have some bulbs to swap.
    [email protected]
    Nemesis Flickr | C43 Build | IG
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by Miranda@Nemesis View Post
    My sq is gone, but I’m still here making dreams come true
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    You always come through Chris! I just go my leds in the mail today
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
    Junior Member One Ring
    Jun 21 2021
    Naperville, IL
    jumping in- what LEDs are you putting in that match well with the rest of the LEDs in the car?
    Senior Member Two Rings robb1887's Avatar
    Apr 24 2021
    Virginia
    Quote Originally Posted by terrspin11 View Post
    I don't understand this question, what LED are you trying to match with your reverse lights that you would use at the same time?
    In terms of "matching" color temperatures, 5000K-6000K is pretty standard. 3000K is yellow, 4300K is "day light/warm white", 5000/6000K is "bright white", anything above 6000K gets into the blues and you start to loose usable visible light.
    For those looking for replacement LEDs for the reverse lights, I've used this brand with great results in a few vehicles, reviews speak well and are error free in my experience. Currently have a coupon available for them for $12 to boot : AUXITO T15 6000K LED bulb pair
    18 SQ5 Prestige
    EPL, ForgedOne, CETE
    Build Thread
    Jun 21 2021
    Naperville, IL
    Trying to match the interior led color temp. I want them to be more OEM like other Audi's have as stock reverse led, and not be too blue or obnoxious. Thank you!
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    What size Torx do I can go buy? T25?
    [email protected]
    Aug 09 2017
    Atlantic Canada
    Don’t buy any. Go in your tool kit in the trunk and there is a double sided one in there that fits.
    Jul 14 2009
    Pasadena
    https://amzn.to/3JYQLff had these for 2 years without issue and its bright white no blue.
    IG: @matthewee
    Mar 03 2004
    Chelsea, MI
    OK, got the 12" T-25, and after 30 minutes of trying to get the T-25 into the screw, I managed to take the light fixture out. What a dumb design.
    Put a new light bulb in, and still no reverse light. Checked the light bulbs for continuity, and they all seem to be fine. I removed the electrical connector a whole bunch of times and wiggled it around. Still no reverse light.
    Now I'm thinking that this is a wiring problem. Any advice?
    Thanks,
    Jan 01 2018
    2021 Q5; 2003 F250
    Southeast PA
    Had the same on my 18 Q5. Dealer determined that the light fixture was bad. Replaced it and was fixed.
    Sent from my SM-G981V using Audizine Forum mobile app
    Mar 03 2004
    Chelsea, MI
    Thanks to scsu, replacing the fixture solved the problem. Purchased a new one (Amazon, $200, 3 days), and struggled with the PITA T-25 screw. Not sure I understand the wiring. 6 pins, 5 bulbs, no common ground or return. Not sure why the old fixture didn't work, everything I looked at said it was OK. But the new fixture works, so I guess I'm good.
    Thanks
    Jan 01 2018
    Idaho Panhandle
    Thanks
    Mind posting link*s) for the replacement bulbs and fixture? I got an error recently saying my rear bulb was out. Light worked and error cleared, but I expect it will come back.
    2018 SQ5 Prestige, S-Sport, Dynamic Steering, APR 91 Stage 1 Tune
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    Thanks
    I can’t even find where the screw is :/ I know it’s through the tow hitch cover but like where the hell is it?
    [email protected]
    Aug 09 2017
    Atlantic Canada
    Miranda, there’s a small notch when you take the cover off on the bumper. It’s directly online with that and up at about a 45dgree angle. The screw has a red surround iirc. Look up there with a flash light and you should see it
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    I’ll look for like the 3rd time. I see a hole but I can’t see a screw. Will check when it’s dark out. Thank ya.
    [email protected]
    Jan 04 2016
    1967 Ford Mustang Coupe 289 w/ 3 on the floor
    Boston, MA
    What worked for me and my 18 SQ5, was there was evidently a large enough opening under the bumper that allowed me to actually see the orange plastic "catch cone" while I was sticking the T25 up and in there.
    Had to persuade it to initially get in there.
    Quite the silly design, but it actually came out and I got it back in the same way, by looking through the back bumper opening.
    Hope that helps!
    2018 SQ5 - Current | 034 ECU & TCU STG 1 | ECS Tuning Intake | Rev9 FMIC | 034 Inserts | 38% ceramic tint
    2010 S4 Prestige - Sold
    Jun 21 2021
    Naperville, IL
    Im with you, on my 21 sq5, I cant find it for the life of me
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    I looked again, this time with a good flashlight and still nothing. I’m convinced it doesn’t exist or they changed it for B9.5. Or I can’t see. No bit of orange anything to even let me know where to look.
    There is a hole, and I stuck a long tool up into it and I see it does wiggle the lights but I would be blindly feeling for any screw…
    [email protected]
    Apr 24 2021
    Virginia
    The double entendre in this post is strong.
    Welcome to every man's fear with a new lady fan.
    18 SQ5 Prestige
    Build Thread
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    iain
