Originally Posted by
Daemotrix
I can get engine by myself. I only want to know, if that swap is doable, and if anybody did that, what is needed to change with engine.
ANY swap is doable... with enough effort and $$... you can put anything into anything. Just look at Bad Obsession Motorsports and Project Binky!
Unless it's a like for like swap, you generally need to change EVERYTHING! Is it belt driven power steering or electric? is the AC connections in the same place or will you need the hoses too? ECU's.. most likely need the donor, but you need to know if it's compatable with the other modules (IMMO, TCU...).
Some swaps are easier than others... some aren't done because of complexity and lack of return on effort!
Good Luck though and keep us posted on your direction!
KS
