Results 1 to 9 of 9
Hybrid View
    Junior Member Two Rings
    Jul 17 2022
    NC
    OBDeleven Long Coding?
    Is there a thread already on here about coding with OBDeleven? I tried searching but netted next to nothing for results that seemed appropriate.
    Backstory: I received my new OBDeleven Pro for IOS in the mail yesterday and scanned the car with it. Some minor faults were found and cleared, but I got looking around and found the long coding options. I started thinking to myself: now how the hell do I use that? A quick Google found me registered on the OBDeleven forums but that place seems to never get any replies to any of the posts.
    There are a few minor things I would like to do with the A7 but have no clue where to start with long coding. Are there any good resources or lists where I can find these codes?
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Long coding will be the same bits and bytes as vcds
    18 S6
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    2016 S6 - sport - optx- atlas - AE nardo
    Jul 17 2022
    NC
    Quote Originally Posted by Audisthesia View Post
    I did not know that. Thanks for the info. Now to go figure out how to do it lol.
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by Hurricane17 View Post
    before you do anything.....MAKE A SAVE PROFILE YOU CAN BACK UP TO!
    that way you have a reference point to go back if you edit something you should have.
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
    Jul 17 2022
    NC
    Quote Originally Posted by THCarpenter View Post
    Can I do that with the OBDeleven tool? Or do I need to save that to my phone or something? I’ll have to look into how to do that while I do my research.
    Aug 14 2019
    Tampa
    Obd eleven automatically records changes as 'history'
    18 S6
    Jul 17 2022
    NC
    So you don’t have to backup anything? It does have a way that you can do a full backup though. I’ve watched a few videos and moved around a bit in the app and found it. And I saw in the history file. It also records all of your faults there.
    Aug 14 2019
    Tampa
    I never said dont do a full backup. I always tell people to do a full backup prior to touching anything. This applies to VCDS or OBD11. I was simply pointing out that if you change some long coding, OBD11 will save that change automatically by recording the long coding for that module before and after your change. Key point here: it records the long coding ONLY for the module you edit.
    18 S6
