Results 1 to 11 of 11
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    AC stopped working
    After fixing some other unrelated issues my ac stopped working out of nowhere. This never happened to me before on my C7 A7 that had higher miles so I知 irritated to be dealing with this in the middle of summer on my S6
    Anyways I did a VCDS scan
    From doing research I was pretty positive it was the ac pressure switch. I ordered one off Amazon prime and installed it, still the same code and no ac.
    The Fan comes on, but When I press the ac button it値l show the light and then the light goes off as soon as I release the button
    I値l post my VCDS scan here
    Is the switch I bought complete junk? Or is my issue something other than the ac pressure switch? Hoping to get this taken care of asap I don稚 want to sweat my a** off on my commute. Any help is appreciated thanks!
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Jun 28 2019
    California
    Quote Originally Posted by Audibellybutton View Post
    Upon further research im still thinking the ac pressure switch is the issue. The one I bought on amazon is probably junk. I purchased it because I needed one before Monday and it was the only one on prime. Didn't think that it would not work at all, but since the code is still the same after changing the ac pressure switch my best guess is that this one is a dud. Since I havent gotten any input ill be returning this one and getting a higher quality or oem one from the stealership tomorrow
    IG:@stolens6
    Established Member Two Rings Rsniper4's Avatar
    Nov 14 2016
    If you haven't already, make an account on Ross-Tech forums and post your entire scan.
    There you will find VCDS nerds that can help decode the data and point you in the right direction. The AC system has many various modules that might disable the entire system if there is a fault in any one of them. They might ask you to monitor live data on specific modules. From there they might detect a module with suspicious values and that might be your culprit.
    2001 A4 1.8T , 260,000 mi (resting)
    2014 A7 TDI
    Jun 28 2019
    California
    Quote Originally Posted by Rsniper4 View Post
    Good call, I signed up on there, will make a thread once my account gets verified
    IG:@stolens6
    Junior Member Two Rings
    Sep 27 2017
    OC
    I had an issue with the AC on my A7 little while back, and my mechanic found a fuse that blew. The AC would kinda work as long as I was moving. The fuse was tucked up in the passenger side corner of the underhood. Some kind of flat metal fuse rather than the normal blade or glass fuses.
    Jun 28 2019
    California
    I did suspect that too, to my understanding its the cooling fan fuses that are located there, Could be a culprit but I ruled it out because it seems like my fans are working as they should. I guess it wouldnt hurt to check anyways
    IG:@stolens6
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    That little fan fuse tucked away under the cross-brace was the culprit when my fan went out. But since your fan is powering up, i'm not sure that would be it especially if it's consistently staying on.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Sep 16 2020
    West Michigan
    My A/C was crap a few years back. Had the dealer check it out while I was there having other work done. Turns out it was 8 grams low on freon.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jun 28 2019
    California
    Quote Originally Posted by 07S6 View Post
    Im positive that A cooling fan is coming on, but the more I think about it, It could be the radiator fan on and the ac fan being out. Hard to tell if both are on, but Ill check the fuses to be sure
    - - - Updated - - -
    Quote Originally Posted by sepheroth86 View Post
    I checked the refrigerant pressure on vcds and it looked fine, but It would hurt to physically check and recharge if necessary. Just weird how it stopped one day after working fine the previous day
    IG:@stolens6
    Junior Member Two Rings Dave4501's Avatar
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    My 2014 A7 had a similar issue about 6 months ago where the AC was working intermittently. I bought a new pressure sensor off Ebay, installed it and my AC quit completely.
    Then I reinstalled the old sensor and my AC has worked perfectly ever since. So I sent the Ebay switch back as non-working.
    I'm not sure why my AC had issues in the first place but I am pleased the fix was easy and free, you might try the same thing. Otherwise, check your freon levels.
    Jun 28 2019
    California
    Quote Originally Posted by Dave4501 View Post
    I just tried this with mine but unfortunately it didnt work, my oem one is really dead then, or its something else
    I want to check the fan fuses does anyone know what size those bolts are on the crossmember? Ill have to take a trip to the parts store to grab the right socket
    IG:@stolens6
