Results 1 to 4 of 4
    Mar 15 2013
    DRC replacement with bilstein - what other parts do I need?
    Hi, going to replace my DRC with bilstein B8's, planning on keeping the existing springs. I gather I should replace the front control arms for sure, as well as the strut mount, bellows. Looking for advice on what other parts people would suggest I order at the same time.
    Thanks in advance.
    Senior Member Two Rings billk1967's Avatar
    Nov 27 2018
    Vancouver
    Hmm, I wasnt aware B8's fit the RS4's. In my review before purchase I only seen the PSSB14 and B16's from Bilstien as the only two options available. I did not see th D8 as another option so you may want to recheck with Bilstien before starting into it.
    As for what else I did while doing the conversion (btw I chose the B14's and had my mechanic install them) I also had them install the 034 Motorsport Density Line Control Arm Kit as my OEM bushing were cracking and creaking. I also purchased this kit to help make the conversion easier for my mechanic:
    https://www.ecstuning.com/b-assemble.../4f0513353dkt/
    I also had them install a Spulen rear diff mount and the rear diff carrier mount bushing insert kit from ECS.
    Hope this helps and good luck!
    2018 Panther Black TT RS
    Mar 15 2013
    Hi thanks for the feedback. That kit surely would help.
    the B8's are on the ecs site (under B7 RS4) also:
    https://www.ecstuning.com/b-bilstein...24-119818~bil/
    I've read others have installed them as well, used the factory springs, and retained close to OEM feel. I don't want to make the ride any stiffer/rougher ideally...
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    If the coilover kit does not include the caps for the DRC lines, you will need to purchase a set. You don’t want to leave them open in case you want to restore use of DRC.
    2008 Audi RS4 Ti Mugello Blue / Ebony
    2004 Audi S4 6MT Saloon Brilliant Black / Ebony
    2012 Lexus CT200h
