Results 1 to 10 of 10
Hybrid View
    Junior Member One Ring
    Dec 08 2021
    PL
    Q5 2009 right DRL not working
    There is no voltage to the headlight on pin 12, the blue-red cable.
    it is probably a PWM led power supply.
    Does anyone know where I can find the other end of this cable?
    or what could be the reason for the lack of voltage in the right lamp
    edit
    The lights are powered by the CECM/bcm module.
    Fault codes:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    012 - Electrical Fault in Circuit
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    left drl works fine
    did anyone have a similar problem?
    if I do not find another solution, I will pull the power from the left to the right but I do not know if the higher load will be good for the bcm module
    greetings
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    This was a common problem with the MY2009-2012 model, there is also a TSB to replace the control module for the DRL
    Dec 08 2021
    PL
    thanks for showing interest
    # 2020780/4 is for damaged drl module in lamp or led strip.
    in my case, the voltage does not reach the headlight
    can anyone tell me where the end of this wire is so that I can check the connection
    https://ibb.co/pQQZXcd
    Oct 10 2010
    Sarajevo, BiH
    As far as I remember the BMC automatically shuts off the voltage when a problem occurs in one of the modules
    What you can try to replace the DRL modules, from the left to try to switch to the right
    Dec 08 2021
    PL
    Quote Originally Posted by spijun View Post
    L module in L headlight works
    R module in R headlight doesnt work
    L module in R headlight doesn't work
    R module in L headlight doesn't work
    Drl module is different.
    by the way, errors were deleted several times, with no effect.
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by Bartlomiej View Post
    at this point, I exclude that the module does not release the current because vcds shows voltage output to both lamps.
    I suspect a damaged cable.
    where can I find the bcm module?
    DRL is same , not is different, for left and right side S/N: 8R0907472B
    BCM or body control module will be located under dashboard on the driver side towards the center of the vehicle
    There are 3 different BMC modules, you need to know which one you have
    Dec 08 2021
    PL
    the BCM is part burned
    it's strange that it even worked
    spijun thanks for your help
    https://s9609.chomikuj.pl/ChomikImag...RBIzBOSnk&pv=2
    Oct 10 2010
    Sarajevo, BiH
    I've never seen anything like it
    It was as if water was dripping on this electronics
    Dec 08 2021
    PL
    Yes its looks like flooding water
    After replacing the bcm to another with the same numbers 8k0 907 063D from a4 b8, it shows an error:
    02095 - Component Protection Active
    the power steering and interior lighting do not work
    coding and adaptation with vcds
    what module should i buy
    Oct 10 2010
    Sarajevo, BiH
    All Audi / VW modules have Component Protection, so they cannot be installed parts from stolen cars.
    This can be done by the dealer or ...................
    https://abrites.com/blog/when-life-g...ent-protection
    https://www.audiworld.com/forums/q7-...3001060/page2/
    Search on internet: CP removal
