The ABS controller in my 2004 A4 1.8T Avant recently started acting up with ABS/EPS faults and the check engine light if I drive too long above a certain speed. When these things happen, the speedometer drops out too. Next time I start the car it runs fine for a while. I have read up on all the posts with the connections inside these modules failing over time and needing to be rebuilt. Vagcom showed the problem as ABS wheel speed sensor front left (G47) open or short to plus -intermittent fault. The sensor was swapped between left and right but the problem stays on the left side. Based on all of this I am guessing the ABS module has the usual issues of broken or flaky connections inside.
So I got a used control module (Bosch 5.7 - both my original and this used one have 8E0 614 517 A embossed on them). Both the original and the used replacement say this on the barcode label at the bottom:
ESP 012 49
H34/S0029
085
The rest of the numbers on the barcode are different however and perhaps they are a date code etc.
When I try to program this new unit I login using 09575 (which is correct for my car per the RossTech wiki) and coding of 04275 and a workshop code of 12345. I press Do it and the correct coding and shop number show up. Then I login using 40168 and in Basic Settings I pick Steering Angle (G85) Alignment. In alignment status it says Locked and the Go button is grayed out. If I switch to measuring blocks and look at Block 5.1, it shows -2.5 degrees and that does not change when I turn the steering wheel per the wiki.
I have tried doing all of this after clearing all fault codes and also tried it with the engine on and off and it makes no difference. When I close the ABS controller screen and go back in, the soft coding and shop number have both returned to 0 probably because the steering angle alignment did not work out. The one fault code I see come up is 00778 Steering angle sensor (G85)
27-00 Implausible Signal
I know that with the original ABS controller I could see the steering angle change when I looked at the measuring blocks.
Would appreciate any help or advice on what to try next.
Thanks
