Hey guys I’ve been having this rough idle cam like idle only in park and after the engine is roughly 180-210 degrees Fahrenheit (warm) in my C7.5 2018 Audi S6. The car needs to be sitting for a little while until warmed up then it starts making this noise in the video I’ve linked. Apparently both motor mounts were done under warranty when I brought it in and Audi is claiming this is somehow normal. There are 2 or 3 others having this issue and it would be much appreciated if anyone can guide me and the others in the right direction toward solving this annoying issue. I’ve done spark plugs (VAG OEM plugs) all correctly gapped and torqued to spec. Car ran better in general but rough idle is still there. Maybe timing chain? Or something engine to transmission related? Turbos impellers on cold side were checked by Audi and they appeared to be normal. Maybe PCV? No squealing now but a few times on startup in the cold weather did have a slight squeaking for about a min (hasn’t happened in a while). When removing the oil cap idle raises and then starts to run a tiny bit rough and I almost heard a metal noise like something going through the engine. I replicated it in front of an Audi master technician and he claims it’s the valve adjusters switching and is normal. Unfortunately I don’t have a video of that noise and can’t get one because car is currently at Audi for roughly the 5th time (between two dealers). Thank you to anyone who can offer insight or help. https://youtu.be/ggTahn282TE
