Results 1 to 6 of 6
    Active Member One Ring spooky007's Avatar
    Sep 18 2015
    2013 Audi A6 3.0T, 1978 Trans Am 4-spd
    Sacramento, CA
    Help with 2008 S5 electrical problems
    I have a 2008 Audi S5 with massive electrical problems following the battery going dead when the shop was fixing an AC leak at the firewall. The EPS light is on and the dash is showing a parking brake problem. The engine starts, revs, and runs enough to move the car around but is otherwise undriveable. It also idles a little rough. Below is the VCDS scan AFTER clearing - these codes come back immediately. Ignore the headlight problem - it is unrelated. Ideas?
    Friday,01,April,2022,18:10:28:46693
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 21.3.0.0
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: WAURV78T78A01xxxx License Plate:
    Mileage: 200100km-124336mi Repair Order:
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
    52 53 55 56 65 6C 77
    VIN: WAURV78T78A01xxxx Mileage: 200100km-124336miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
    Part No SW: 8T0 907 560 G HW: 8T0 907 560
    Component: 4.2l V8/4V H10 0009
    Revision: 76H10---
    Coding: 01140009180F0120
    Shop #: WSC 34412 001 1048576
    VCID: 3E733430A9C1D07BF1-806A
    15 Faults Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 001 -
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 618 /min
    Load: 40.4 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.843 V
    P1653 - 008 -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 618 /min
    Load: 40.4 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.843 V
    001112 - Evap System Purge Control Valve (N80)
    P0458 - 002 - Short to Ground
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 603 /min
    Load: 42.7 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.208 V
    004199 - Intake Air Switch-Over Valve (N335)
    P1067 - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 603 /min
    Load: 42.7 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.462 V
    005173 - Secondary Air Pump Relay (J299)
    P1435 - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 603 /min
    Load: 42.7 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.462 V
    008853 - Fuel Pressure Regulator Valve (N276)
    P2295 - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 603 /min
    Load: 42.3 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.462 V
    004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
    P129C - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 603 /min
    Load: 42.3 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.462 V
    000256 - Mass Air Flow Sensor (G70)
    P0100 - 002 - Supply Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:24
    Freeze Frame:
    RPM: 600 /min
    Load: 42.3 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.462 V
    P0100 - 004 - Supply Voltage
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:25
    Freeze Frame:
    RPM: 628 /min
    Load: 38.0 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 14.224 V
    000135 - Fuel Rail/System Pressure
    P0087 - 002 - Too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:27
    Freeze Frame:
    RPM: 620 /min
    Load: 38.8 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 14.224 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
    P0031 - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:29
    Freeze Frame:
    RPM: 621 /min
    Load: 38.8 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.970 V
    000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
    P0051 - 002 - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:29
    Freeze Frame:
    RPM: 621 /min
    Load: 38.8 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.970 V
    009217 - EVAP Leak Detection Pump Control Circuit
    P2401 - 002 - Short to GND
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:34
    Freeze Frame:
    RPM: 616 /min
    Load: 38.8 %
    Speed: 0.0 km/h
    Temperature: 97.0°C
    Temperature: 45.0°C
    Voltage: 13.843 V
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
    P0036 - 004 - Malfunction / Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:34
    000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
    P0056 - 004 - Malfunction / Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:11:34
    Readiness: 0110 1101
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 J HW: 8K0 907 379 J
    Component: ESP8 quattro H03 0190
    Revision: -------- Serial number: --------------
    Coding: 110500
    Shop #: WSC 06325 000 00000
    VCID: 408F4AC8D335A68B83-8014
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 289 G HW: 8K0 907 289 G
    Component: BCM2.01 H38 0253
    Revision: 00002001
    Coding: 0F0000
    VCID: 3D71333CA4C7CB63E8-8068
    Subsystem 1 - Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
    Component: ELVAUDIB8 H34 0039
    Serial number: 0207000000503005
    Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
    Part No SW: 8T0 959 760 HW: 8T0 959 760
    Component: MEM-BFS H08 0027
    Revision: AA000000 Serial number: 00001001022248
    Coding: 00017025002C44110000
    VCID: 55A18B9C3CB73323C0-8000
    Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
    Part No SW: 8T0 035 729 D HW: 4E0 035 729 A
    Component: Interfacebox H43 3010
    Revision: 00000000 Serial number: 340HT077503893
    Coding: 0025003
    Shop #: WSC 26131 444 94268
    VCID: 3A7B382075E9FC5BCD-806E
    Subsystem 1 - Part No: 8T0 919 609 D
    Component: E0380 BedienteilH07 0100
    Subsystem 2 - Serial number: 00000000012682
    Subsystem 3 - Serial number: 0101.08.070000000100010140ÿ
    Subsystem 4 - Serial number: 010140ÿ
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T1 820 043 R HW: 8T1 820 043 R
    Component: KLIMA 3 ZONEN H05 0110
    Revision: C1000000 Serial number: 0123.08.070013
    Coding: 48022000
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H20 0253
    Revision: 05020001 Serial number: 00000000029650
    Coding: 26001091001CAF010000080300003D3D4F1C12880001016100 0000
    Shop #: WSC 26131 444 84544
    VCID: 306F1A086395360B73-8064
    Subsystem 1 - Part No SW: 8T1 955 119 B HW: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 130807 H13 0040
    Serial number: SWFBIE 0000179
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B
    Component: RLS H12 0001
    Serial number: 10013313
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
    Component: E1 - LDS H07 0070
    Serial number: 00000000002008070071
    Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
    Component: UGDO HL US H04 0060
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 8T1 035 110 A HW: 8T1 035 110 A
    Component: MP3-Changer H41 0350
    Revision: 00041003 Serial number: AUZ5ZBG4018467
    Shop #: WSC 00000 000 00000
    VCID: 285FF2689B457ECBAB-807C
    Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
    Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
    Component: SDAR SIRIUS H07 0140
    Revision: 00000000 Serial number: AUZ4Z7G0126187
    Coding: 0000100
    VCID: 2F6D1974BEAB29F36A-807A
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:12:18
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0003
    Revision: 11001001 Serial number: 46130722004172
    Coding: 200002
    VCID: 76E3EC10C171583BE9-8022
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H49 0610
    Serial number: 003GLDD02K8A
    Coding: 303338334330303030304A55304C38543053
    Shop #: WSC 55437 002 1048576
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 45815BDCC41783A3B0-8010
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
    Component: BF-Gewichtss. H01 0040
    Serial number: 5810000R0700000D96
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME5F5B6B36Z
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 6344MSME5F5B6B33X
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 6352QSME3673313BE
    Passenger side rear thorax airbag crash sensor:
    Serial number: 6362QSME34742E63L
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME4E1717493
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME321B2913W
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H10 0012
    Revision: -------- Serial number: 90315GHF0000B
    Coding: 000016
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 980 P HW: 8T0 920 980 P
    Component: KOMBIINSTR. H21 0212
    Revision: 00000000 Serial number: 6C422D887
    Coding: 8B1D01000300D705020001
    Shop #: WSC 06325 123 12345
    VCID: 489F52E8FB059ECB4B-801C
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
    Component: GW-BEM 4CAN-M H07 0084
    Revision: EB002032 Serial number: 3200E077308056
    Coding: 000003
    Shop #: WSC 26131 444 85772
    VCID: 448746D8C72DBAABA7-8010
    Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
    Component: J367-BDM H06 0150
    Serial number: 1700338A010807
    Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
    Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
    Component: SG ext.Player H15 0700
    Revision: 00000000
    VCID: 275DF154565B71B3A2-8072
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Component: MEM-FS H08 0027
    Revision: AA000000 Serial number: 00001001022251
    Coding: 00197B25002C44110000
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
    Component: MNS US H50 1100
    Revision: 00000000 Serial number: 341HP077503762
    VCID: 387F22284BE5EE4B3B-806C
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 HW: 8K0 959 793
    Component: TSG FA H09 0149
    Revision: Serial number: 0
    Coding: 011C13225E002201
    VCID: 7DF1F33CE4470B63A8-8028
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0106184372
    Coding: 01060E9A007A44C700B000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0040
    Serial number: 00000000000000004518
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
    Component: J245EE16SKB09 H01 0170
    Serial number: 0123456789ABCDEFGHIJ
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 M HW: 8T0 035 223 C
    Component: DSP Prem H12 0280
    Revision: 00H12003 Serial number: 34813000435302
    Coding: 020101
    Shop #: WSC 12336 024 394758
    VCID: 387F22288BE5EE4B3B-806C
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 HW: 8K0 959 792
    Component: TSG BF H09 0149
    Revision: Serial number: 0•b
    VCID: 7CF7FE38FF5D026B9F-8028
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
    Component: EPB Audi B8 H03 0040
    Revision: 00000003 Serial number: 00000000014950
    VCID: 2F6D19747EAB29F36A-807A
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:12:07
    Freeze Frame:
    Voltage: 13.90 V
    Count: 58
    Speed: 0.0 km/h
    Hex Value: 0x02F3
    Hex Value: 0x0001
    Hex Value: 0x1010
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8T0 907 357 A HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000017
    VCID: 3C773E387FDDC26BDF-8068
    Subsystem 1 - Part No: -----------
    Component: AFS-Modul links
    Subsystem 2 - Component: AFS-Modul rechtsH06 0002
    1 Fault Found:
    02233 - Left Headlight Power Output Stage (J667)
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 200100 km
    Time Indication: 0
    Date: 2007.06.16
    Time: 08:12:10
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 336HL077514320
    Coding: 0000002
    VCID: 2E530470B9A120FB61-807A
    Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
    Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
    Component: J502-RDK H03 0240
    Revision: 00001001 Serial number: 12822707120059
    Coding: 0CD154
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 HW: 4L0 907 441 A
    Component: J772__Rearview 0040
    Revision: --H12--- Serial number: 525PA8-J7750I5
    Coding: 1000008
    VCID: 75E1EB1C1C775323E0-8020
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4F0 910 336 E HW: 4E0 862 335
    Component: Handyvorb2 H18 0950
    Revision: 00000000 Serial number: 00000005004699
    Coding: 0010900
    VCID: 2541FB5CEC5763A390-8070
    End-------------------------(Elapsed Time: 03:53)--------------------------
    Jul 16 2018
    Atlanta
    N80
    N335
    N276
    J299
    G70 MAF
    all four O2 heaters
    Says to me there's an issue with the fuse 5 in the ECM box, or the wiring from that fuse to the devices. Is that fuse blown?
    The heater circuits are fuses 9 and 10 in that same ECM box. Check all the fuses in the ECM box.
    Sep 18 2015
    Sacramento, CA
    You're the man! Nailed it first shot out of the gate!
    Fuse 5 was blown. Replaced it and it immediately blew again. Replaced a second time and was able to clear all but "004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)."
    After a few minutes, the Fuel Rail System Pressure too low (1010 mbar) and the parking brake error came back. EPC never turned off and the engine continues to run rough.
    I stopped and started the engine a couple of times after re-seating the wire connectors and tapping on the fuel pumps with no change. The third time I started the engine, the fuse blew again and all 15 engine codes came back.
    So... Would a bad fuel pressure regulator short and cause this to happen? Should I just replace the sensor or the pump too? Any test I can do on the sensor?
    Jul 16 2018
    Atlanta
    You'd have to test through to see where the short is. I'd start by testing the fuse slot for continuity to ground (one side is connected to battery, one side goes to the devices, it's the devices side you want to test). Once you confirm short to ground on that side of the fuse, then you need to find which device's power wire pin is short to ground. The DTC for the fuel is going to come up as soon as the power is down and the engine is running, so that doesn't id that device specifically as the problem. You could test the power pin to ground pin on the HPFP for continuity to see if it is the pump grounding the power. But it's more likely somewhere in the wiring harness between the fuse and the downstream devices. Have to look for a frayed wire or such.
    Sep 18 2015
    Sacramento, CA
    It definitely appears to be the LH fuel pressure regulator/high pressure fuel pump. I replaced the fuse again, unplugged the RH fuel pressure regulator and reset the codes before starting the engine. Only 2 codes came back:
    004764 - Fuel Pressure Regulator Valve; Bank 2 (N276) - Open circuit
    000135 - Fuel Rail/System Pressure - Too Low
    EPC stayed on, but the fuse didn't blow and the engine ran smoothly. The car was drivable up to 3000 rpm (where the engine cut out due to not enough fuel pressure). After driving, no further codes popped up.
    Interestingly, I found a YouTube video showing my issues almost exactly: https://www.youtube.com/watch?v=WX8q4t_WAoE
    My car had also fried its ECU about 6 months prior, but was running fine up to this latest episode. This was probably the root cause. Prior to its replacement, there was NO communication to it and no start, so no codes.
    I'll let you know the results following replacement, but expect this to be it.
    Sep 18 2015
    Sacramento, CA
    That was it. Installed new HPFP and car runs perfect with no codes. Thank you Smac770 for pointing me in the right direction!
