Results 1 to 16 of 16
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    :: EuropaParts.com :: Ross-Tech's VCDS Vag-Com Starting at $199.00 SHIPPED!
    Vin Limited Interface FAQ...
    Why sell VIN-Limited interfaces?
    Because it allows us to charge for the product in a manner that's somewhat commensurate with how the product is used. A professional workshop that's in and out of several vehicles a day with their VCDS gets considerably more value from the product than a private individual who only uses it occasionally one one or two of his own cars. When the previous generation of interfaces was designed 10-12 years ago, most VW/Audi cars on the road did not yet know their own VIN, so it was not really practical to restrict usage that way. Hence the pricing on our universal interfaces (interfaces that worked with all the cars available at that point) had always something of a compromise. Plenty of workshops told us that VCDS was the best value for the money of any tool they'd ever bought and that we could/should charge more, but we were already at or close to the limit of what an enthusiast would pay, and enthusiasts were (and still are!) a very important part of our business. In fact, the reason this product exists is that I got frustrated that I couldn't trouble-shoot my own cars anymore in the late 1990s. Some pros suggested that we make a less expensive version for enthusiasts by restricting the what the enthusiast version could do, but that was not an approach that was palatable to me. So now a decade later, most of the cars people are working on do know their VINs and restricting the number of cars an enthusiast can perform certain functions on seems like a reasonable way of differentiating between a "pro" and a private individual.
    Will VCDS count a car's VIN as toward the license limit as soon as I plug into a particular car?
    No! VCDS will never count a VIN toward the license limit without the user's explicit permission. It will always ask you first, thereby giving you the opportunity to decline to "register" a VIN in the interface. Besides, there are a lot of useful things you can do on an unlimited number of cars.
    What functions are not VIN-Restricted?
    A VIN-Limited interface can do Auto-Scans, Clear DTCs, and look at Measuring Values on an unlimited number of cars. I think this is important because I wouldn't want to keep an enthusiast from doing basic diagnostics on his friends' cars, or to use his VCDS when evaluating used cars he's contemplating buying. You wouldn't buy a used car without doing an Auto-Scan on it first, right? In addition, you can make channel maps on an unlimited number of cars because sending us those maps helps us improve the product.
    What functions are VIN-Restricted?
    • In essence, it's those functions that actually change things in the car:
    • Adaptation
    • Basic Settings
    • Changing Codings
    • Changing the Gateway Installation List
    • Login or Security Access
    • Output Tests
    • Optical Bus Diagnostic
    • Readiness
    • Resetting SRI
    • Turning Transport Mode on or off
    In addition, directly accessing a control module outside of an Auto-Scan will prompt the user whether he wants to "register" that car's VIN, but declining to do so at that point will not prevent access to the module.
    What about older cars that do not know their VIN?
    Simple: They are free. You can do anything and everything on those cars without them counting toward the license limit.
    Which cars do and don't know their VIN?
    Virtually all model year 2002 and newer do know their VINs -- basically those cars with Immo-3 and up. I believe the only model year 2000 car that had Immo-3 was the Audi A8, but a few others got Immo-3 in model year 2001.
    If I sell one of my cars, can I de-register and free up that VIN slot?
    No, it doesn't work that way. VINs are stored permanently. They cannot be erased.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Hey Hugh! Been a long time, if you remember me from the B7 A4 forums like 10 years ago lol.
    Just picked up a 2018 SQ5 and a 2021 S4. How many vins can this work as a full featured vag-com for?
    Sent from my SM-G996U using Tapatalk
    2021 Audi S4, P34 Intake
    Aug 22 2010
    Piscataway, NJ
    You can use it on as many cars as you'd like, however, if you change anything it "uses a vin" so the 3 vin will give you 100% full functionality for 3 different cars. #B7gang
    Dec 03 2008
    2018 SQ5
    Thank you!
    Aug 22 2010
    Piscataway, NJ
    Thank you!
    Anytime!
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    Hi, what VDCS interface would work with a Google Chromebook if any? Second, would you know what is the least cost MS Windows device found used that works? Thanks
    Sent from my motorola one zoom using Audizine Forum mobile app
    AKA: gjweyman
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by SideMirror View Post
    VCDS requires a computer running Microsoft Windows (the HEX-NET can be used with VCDS-Mobile on other platforms but that use is still in beta testing). A Laptop is most convenient but a desktop PC can also be used.
    We recommend a PC running Windows 7, 8.1, or 10 with at least 2GB of RAM Screen resolution of at least 800x600 is recommended.
    If you are using a power supply for a laptop, it should be one specifically designed for that purpose, NOT a "universal" adapter.
    Systems running Windows in a virtualized environment (for example Virtual PC on a Mac) are not supported.
    "Surface" and "Surface Pro". The regular "Surface" tablets are based on ARM CPUs running "Windows RT" and have no compatibility with normal Windows "Desktop" programs. The regular Windows-based version VCDS will not work on these, but VCDS-Mobile does. The "Surface Pro" tablets use Intel CPUs and Windows 8 Pro, and VCDS will works fine on them.
    Sep 10 2022
    2003 Cobra Vert / 2018 S4 Prestige
    Ocala, FL
    Wow this sounds like a good deal, might have to grab one.
    Jan 04 2009
    ne
    Quote Originally Posted by Hugh@EuropaParts View Post
    forgive the newb question. But does this allow me to turn off the soundator or whatever that enhance sport noise maker is called?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by rlme36 View Post
    Good morning, you should be able to do that through MMI.
    Jun 07 2015
    Madison, WI
    Windows 11 supported?
    2010 GTI APR Stage 3 K04, VWR springs, UniBrace.
    2013 Golf R APR Stage 2, APR DSG Tune.
    2012 B8 S4 DSG Sport diff. APR Stage 2 V4.0, APR TCU tune, JHM 187 lower pulley, Modded air box, silicone tube, CR-15 (sold).
    2019 S4 APR Stg 1 tune, TCU tune, intake, FMIC, 034 Rear bar, ECS inserts, Koni Special Active Red shocks, 034 shock mounts, Mops 10/12 spacers.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by davesxx01 View Post
    Absolutely.
    Mar 21 2015
    Did Rosstech crack the FSD2 for VW yet?
    Aug 22 2010
    Piscataway, NJ
    Good afternoon, not that we are aware of.
    Aug 22 2010
    Piscataway, NJ
