Results 1 to 16 of 16
    May 20 2020
    Caribou, Maine
    RWD conversion kit
    Has everyone seen the new product ECS releasing which is a RWD conversion kit? It looks like it currently will be available for the manuals. Anyone plan on getting this?
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    I noticed that too on ECS. I just wonder how the rear end can handle all the power as you know the people that would do this would be people that want to do weekend drifting events. Aka high abuse situations. Still very interesting, but I have no plans on getting it.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    May 20 2020
    Caribou, Maine
    I also have no intentions on buying it as I live in an area that gets a lot of snow so the AWD is good. I was honestly just surprised to see it.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    rwd probably can handle 500 hp these cars put out when modded. I do think that removing the torque from the front wheels on this platform can negatively affect handling outside of drifting etc. My understanding is that the front wheels are used to pull the car into the turn, more so than the rear wheels are used to push especially if there's no sport diff. I might be totally wrong, though, I do think that this is probably true because I've heard that according to JXB, the front differential upgrade has the most effect and front tires tend to wear quicker than rears when track driving - this part I'm not so sure about. I'd actually prefer if somebody could retrofit macan's center diff. the trans appears to be very similar, the only difference is center diff which is not permanent awd but an on-demand type with torque going to the rear wheels most of the time.
    Sep 16 2020
    West Michigan
    Quote Originally Posted by fastboatster View Post
    Most cars wear the fronts faster on road course because there is more weight up front. So the front tires take most of the cornering load.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Apr 23 2019
    CA
    Quote Originally Posted by sepheroth86 View Post
    true. I've probably heard that the front wear on the s4 is very egregious, but that's my speculation.
    Aug 16 2020
    Q
    I ran a set of tires and never rotated them. The fronts had 3mm and the rears had 6mm of tread remaining after 25K. With that said, a "RWD Conversion" is some of the dumbest shit I've seen on this site.
    May 20 2020
    Caribou, Maine
    Quote Originally Posted by Izzyz28 View Post
    You talking about my post or that ECS tuning is making the conversion?
    Aug 16 2020
    Q
    Quote Originally Posted by Theo9 View Post
    The fact that ECS is making this.
    May 20 2020
    Caribou, Maine
    I was also very surprised to see it lol. Can’t imagine many people will be interested in it as one of the reasons people like this car is the AWD.
    Aug 16 2020
    Q
    If these cars weren't AWD, they would have absolutely nothing going for them IMO.
    Junior Member Two Rings
    Sep 28 2008
    Australia
    A4 guys will be frothing at the mouth.
    May 20 2020
    Caribou, Maine
    RWD conversion kit
    Quick question, I’m not to familiar with the build differences between manual and automatic. But I noticed they are only releasing the conversion for manuals. Where would the difference be for the conversion between an automatic and manual? Just looking to learn more about our car!
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    These car push too much to be serious track cars. Probably 75% of the motor is hanging over the front axle. That's why your tires wear so fast and 8 control arms are needed per side, lol.
    I agree tho, just the idea of converting to rwd seems crazy to me.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    What a pointless mod, if you want rwd buy a proper rwd car, even a shitty mustang has better rwd dynamic than a s4. I bought an Audi because of real Quattro (won’t buy a s3/tt for that reason.
    Sep 16 2020
    West Michigan
    Quote Originally Posted by Slvrbul8 View Post
    They push because of weight distribution, yes.
    The tires wearing is due to the fact that the front tires do most of the braking and turning. So they receive the majority of the work.
    Ball joints in-line (front to back) like our cars have provides greater stability at high speeds. It has nothing to do with weight. One Ton Dually pickup trucks that weigh 9,000 lbs only have one upper and one lower balljoint, but they do not go 160+mph.
