Hi all! Happy 2025! Been a bit so wanted to drop in an update.
Most recent repair was to swap out the radiator which was the only part I hadn’t replaced during the last round. Plastic end tank gave up the ghost after I put the car back on the road for a week. It must have decided it was retired after being in the garage for so long.
The foam around the fan shroud was reduced to dust so I bought what I thought might work dimensionally from Amazon. I completely overestimated how much space there is between the shroud and the rad. Wasn’t even close to compressing so had to get creative (taking it off would have made a total mess.) Test fir the rad in the bottom mounts and then leaned it in at the top and zip tied it in place to compress the foam. Used the indentations to mark where it needed to be carved out. 4-5 test fits and she was good.
Next was the new AC condenser. It wouldn’t hold a vacuum and while there was no obvious oil staining on it I really don’t want to go back in so bought one from FCP. Nissens. Same as the rod but the quality of this piece was, welll….off. Dented on the top edge, paint looked terrible, the sticker fell off and once mounted, I could see relative to the radiator, the whole thing was bent - bowed in toward the engine. Annoyed, I took it off and will have to return it.
Thanks to Shelby, I was reminded there are still plenty of things to do on a C5 so decided to swap in the fuel filter I’ve had in the cabinet for several years. Naturally, the filter Mahle KL-36, didn’t come with any of the for crush washers needed to I was able to source two at a dealer and had two which were dimensionally identical to the ones that came off the car. Nice try, Dave.
While the washers were identical, the filters aren’t. The Mann that came out had a flat matting surface on the inlet side and the Mahle has a recess cut where the seal ring sits. Ring was too big…fuel spraying like champagne on New Year’s Eve.
I’m done chasing parts like that at the dealer and have a Belmetric assortment on the way including what seems to be the 14x18 I need for this filter (14x20 is what came out).
Connected the coolant lines on the rad and then moved onto the trans cooler lines. <sigh>. Top one was easy but the bottom…well, you guys know. I ended up zip tying the trans cooler lines to different AC lines to keep the alignment while I threaded the bolt. Whoof. Miserable but done.
Last repair was to the wiring for the condenser fan…saw it was torn and wires exposed. Hair dryer to soften and then rescue tape to seal and tuck back in its keeper.
Here’s the new filter with the recess cut for the seal ring. Should spotted that on the bench. Live and learn.
