Results 1 to 20 of 20
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    Denver Emissions
    I just moved here and have a B8.5 S4 w/ 034 TCU and ECU tunes…
    I need to register my car, which seems like a huge PIA, and I’m wondering if I need to flash my ECU or if I will pass with the tune…
    Sorry if this is the wrong place for this.
    Ernie
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    If you have your stock cats, I would guess you'd be fine, but you just never know lol. I have a B8 S4 with dual pulley 034 tune, but I've never done emissions on it since I register in an exempt county. It's always safest best to tune back to stock. If you don't have a flash cable, Berg Performance is the local 034 tuning shop, and a fantastic shop all around.
    Sent from my SM-G996U using Tapatalk
    2021 Audi S4, P34 Intake
    Dec 30 2012
    Mountain View, Ca
    Awesome!! Thank you!! The local 034 shop was going to be my 2nd question!
    I do have the stock cats and it passed in CA last year. I’ll try it as it first and then flash it if I have to.
    Cheers
    Jul 10 2015
    Colorado
    If it passed in CA, it will likely pass here.
    Junior Member One Ring
    Jul 03 2019
    Denver
    Based on this thread it seems that CO has followed suit with California in checking the ECU for tunes. Has anyone else run into this yet? I can find no announcements, info, anything that states CO has implemented the ECU checks here in CO quite yet.
    https://www.audizine.com/forum/showt...8#post14804618
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    My 911 passed this summer without issue with a tune. Granted it has cats and all the readiness monitors are set/intact etc.
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    I gave up and have been driving with tags that expired in 2019
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    I just passed emissions last week with no issues. Flashed the ECU back to Integrated Engineering's stock file and drove for a few miles to set readiness
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Jul 03 2019
    Denver
    Quote Originally Posted by Brother Owl View Post
    That's good to hear. I wish it were that simple for me but I'm in pretty deep on my car and a simple flash back to stock won't work in my case
    Veteran Member Three Rings Aok303's Avatar
    Jul 11 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    you just need your cats and all the readiness monitors are set/intact etc, even with stage one tunes they will code secondary checks out and to pass they have to be able to read now for emissions
    My GTI had to get a new file last year due to that's when the change came, my S4 is next year to run emissions so will see as im DP stage 2 plus >.< but still stock cats
    2016 Noggy S4 - Stock and loving it.... Jk its not stock
    Feb 02 2005
    That's not true anymore. You need the check sums and CVN's to match what the factory stock tune says they should be. Most tuners are changing both of those, so if you roll in with a tune, even though you have cats and all the monitors are set, you're still going to fail.
    '17 KTM 690 "Adv"
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Bumping an old thread to see if anyone has had any issues passing with a tuned ECU recently. I just finished rebuilding my B7 S4 and knew it wouldn’t pass due to being cat-less (tuned as well) so I registered in GJ at my nephews’ address. But my B8 is due for emissions and has a stage 1 tune so I’m wondering if I should do the same as the B7. It was pretty effortless to register in Mesa County honestly, but just looking for anyone who has recent experience with these emission changes.
    .....powered by quattro
    Cheers,
    Ry-man
    Established Member Two Rings B0bbyB0b's Avatar
    Apr 19 2018
    2020 RAM 1500 Laramie, 2011 Acura MDX
    Northern Colorado
    Well here are...welcome to CA, I mean CO.
    I am at my wit's end with this! Failed two emission tests because of evap readiness. It has been quite a show up to this point. Passed with a tune during COIVD as they were not checking software tuning then. Now they are...so failed my latest emissions test (as they run tamper software now). Flashed back to stock and drove a while (per IE). Made my appt in Greely and failed that due to evap readiness. Dfove longer and still no go. Car sat at Audi for two days and they couldn't figure why it's not flipping. Took it to Berg Perf in Denver (awesome dudes BTW) and had them flash to a clean stock file for me. Drove around more and still no go. They called and stated they figured a way to force the test to run to get to ready (success on another b8 s4) and they were able to pass emissions test. Figured I would drive around more and see what happens...nope, still no go. Went back to Berg and had them try it and they could not force the test for some reason.
    I am tired of chasing this...It has been 2k miles since I failed my first inspection and I am running all over the place with this thing to get evap to flip. All because someone at the state level thought it would make a diff. My car has passed emissions with a tune on it before...why not now!! Anyone have this issue and figure out how to force test the evap????
    2014 B8.5 S4 Premium Plus
    6MT | Rear Sports Diff | Tech Package | Misano Red Pearl | Magma Red Interior
    IE Stage 2 Tune | Pulley Swap | IE CAI | HRE FF01 Liquid Silver Wheels 19x9.5 et45
    Michelin Pilot Sport 4S | EBC Slotted Rotors w/Akebono Ceramic Pads
    Bilstein PSS10 Coilovers
    Gone But Not Forgotten: 1982 Audi GT Coupe (B2) | 5MT | I5
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    CO emissions is a huge pain now. Always was about as bad as Cali but now we are basically just as bad. Any CEL will fail you no matter what it is for. All readiness codes must be set to ready. No tampering or tunes detected. Gas cap integrity must be up to par. Smoke test must be passed with catalytic converters intact.
    It's all bullshit IMO. If you pass the smoke test, which is that actual sniffer test/exhaust test, they shouldn't care about your CEL or anything else. It is an EMISSIONS test! If the car is emitting within the acceptable range it should pass IMO. They make it such a pain in the ass now.....
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Junior Member Two Rings Barong02's Avatar
    Feb 20 2023
    '95 R33 Skyline GTR
    Colorado
    Yeah, the big change is that you can't show any ECU tampering or tunes. All of the others constraints have existed before, but adjusting tunes was the easiest way to get around them.
    2018 S6 Stage 3
    Jul 11 2012
    well about to fight Co to get my s4 to pass
    Jul 11 2012
    super easy got it on the first try
    Feb 20 2023
    '95 R33 Skyline GTR
    Colorado
    Do you mind sharing what mods you had and if you removed the tune (if so which one)?
    2018 S6 Stage 3
    May 29 2012
    Evergreen, CO
    https://cdphe.colorado.gov/APCD/Outr...issionstesting
    Its gonna get worse than it already is.
    2025 RS6 Avant Performance
    2020 SQ5
    2018 RS3
    2015 B8.5 S4
    2007 RS4 Phantom Black
    2007 RS4 Mugello Blue
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Most of the tuned guys I know in Colorado get South Dakota plates.
