Results 1 to 14 of 14
    Jul 23 2013
    1989 Saab 900 SPG, 1988 Saab 900 Turbo Conv
    Philadelphia area
    Question Possible to replace the wastegate actuator on a K03 turbocharger?
    My 2008 A4 Avant with 2.0T engine seems to have a bad diaphragm in the wastegate actuator. I believe the actuator is riveted to the turbo and yet I see aftermarket actuators that will bolt on to the turbo. Does anyone know if it's possible to service or replace the actuator instead of replacing the entire turbo?
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    There are some videos that talk about heating it and bending it to solve the play… never tried it though
    Jul 23 2013
    Philadelphia area
    How does that address a torn diaphragm?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by Ray1031 View Post
    Yeah, that won't help here. And thats a B8 fix, b7 is adjustable.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jan 21 2018
    frackville, pa US
    Yes, ya can replace the actuator.
    Jul 23 2013
    Philadelphia area
    That's what I thought. ECS and FCP don't sell them but I did find a couple from other sources.
    https://www.ebay.com/itm/28312699723...torefresh=true
    https://turboturbos.com/products/a-0...RoCUoYQAvD_BwE
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    first thing first, atleast vaccum test it before coming to conclusions.
    Think about it- is it worth the effort spending 100-150 on a good quality one when you can get a used or rebuilt for for 350-400, replacing turbo itself is 3-4 hr job if you are doing it first time. Do you really wanna trust vaccum actuators from ebay? Do you know how precisely actuactor needs to be installed? if not, it will burn out turbo in couple days.
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Yes. I replaced mine with a forge actuator for a B7 A4 and I have a B8 A4.
    Sent from my LM-V450 using Audizine Forum mobile app
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Jul 23 2013
    Philadelphia area
    Thanks all. I will be replacing the actuator and N75 valve. I've removed and installed turbos multiple times on this car, not interested in doing it again if it's only $66 to replace the parts that are actually bad. And yes, this was all confirmed by a well-respected, high-end Porsche-racing shop. The actuator will be properly installed and adjusted.
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by Jeevan View Post
    Can get an actuator pretty cheap, and its just a diaphram.. Don't need to be "precise", it bolts right on, then you adjust the preload, shouldn't be very hard..
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by Jayz691 View Post
    so no boring, pressure testing the housing or measuring the size of the existing hole. wah, its like rebuilding the engine without measuring tolerances.
    Jan 21 2018
    frackville, pa US
    What are you talking about, pressure testing the housing? And measure what hole?? Where talking about the WG actuator, not the WG flap/bushing unit... Think your confused..
    May 15 2019
    Bellevue, WA
    did you ever think why waste gates go bad apart from bushing? may be some youtube search will help
    Jan 21 2018
    frackville, pa US
    Dude, what are you talking about?? Yes, we know why WG's go bad.. Thats not what hes asking. Hes asking if you can replace the actuator.. Simple, yes. Why are you babbling about other stuff?? Don't need to search you tube. Wow. And normally the bushing dont were, the flap/cover wears. But AGAIN, thats not what hes asking..
