Results 1 to 11 of 11
    Jun 24 2018
    IL
    Anybody have any experience with these codes?
    Hey guys,
    I've had my RS3 for a little over a month, and twice now I've had these two codes pop up, and was curious if anyone has had these before.
    P050700 - Idle Control System RPM Higher than Expected
    Intermittent
    U010100- Lost communication with TCM
    Next time it does it, I'm taking it in, but from my ignorant readings, it sounds like it could be the DSG or Mechatronics, I have warranty, but hope it's not that.
    Anyone else have these?
    Thanks
    2018 RS3 Daytona Gray
    Established Member Two Rings Porra46's Avatar
    Mar 02 2021
    South Africa
    P050700 is definitely a vacuum leak. Is your car stock? I got this code after fitting my turbo inlet. The hose clamps from the PCV to the inlet was not tightened enough.
    That other code I have seen come up when the car is flashed via the OBD port. But after clearing the code it doesn't come back.
    Sent from my SM-G975F using Tapatalk
    2012 VW Golf Mk6 R - APR Stage 3
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Agree with Porra46, P050700 - Idle Control System RPM Higher than Expected, is some kind of leak or dying PCV, and U010100- Lost communication with TCM, usually comes up after flashing the tcu, but once you clear it, it shouldn't come back.
    Stage 1 more than you RS3
    Jun 24 2018
    IL
    Okay I'll check out my intake system and locate the PCV hose and make sure all is tightened.
    As for the TCM, I'm currently on DS1 E85 and it popped up once a couple days after flashing and heard it was common and it went away. Move forward a couple weeks, and 2 days ago it popped up again. I am currently on a Uni stage 2 TCU file and have been for about 3 weeks now.
    Mar 02 2021
    South Africa
    Quote Originally Posted by CavEsk1337 View Post
    Just a reminder bud.
    U010100 will appear every single time you reflash your car. You will even get similar messages in the Central Electronics, and even AWD controller. In fact there are a few other controllers thst also get this similar message.
    I use Uniconnect and when I flash between tunes from 91 to 93 this always happens. I always scan all controllers and clear everything after a flashing session.
    Feb 06 2012
    Allentown, PA
    try flashing back to stock tcu and see if it comes back....
    Mar 09 2018
    2018 RS3
    Seems like you bought the car used. Any other mods we should know about?
    Florett RS3+DS1+034TCU
    Jun 24 2018
    IL
    Thanks for the response guys.
    I purchased "stock", but looked to have been modified prior and put back to stock. I added: DS1 Stage 1 E85, Uni Stage 2 TCU, and Uni Midpipes at this time. My intake isn't on yet due to waiting on 034 to send my 4" inlet :(
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    I just got this code for the first time 2 days ago. After some spirited driving, I popped the hood and let the car run for a few minutes to cool down. I noticed it started idling higher than usual but didn't think much of it. I turned the car off (didn't check the dash for a CEL) and went about my business. The next day I started the car and immediately saw this CEL. I cleared the codes and the car seemed to idle and drive normally afterwards. The code hasn't come back. I wonder why it started to idle high in the first place. No visible loose connections or obvious vacuum leaks. I did tighten the gas cap but it seemed secure. Can't think of what else it could be.
    Sent from my Pixel 4a using Tapatalk
    2018 nardo gray rs3 - sold
    Mar 02 2021
    South Africa
    Quote Originally Posted by jd_rs3 View Post
    Could be a sign of your PCV starting to give issues. Although I haven't heard of these motors giving PCV issues really.
    Feb 18 2019
    Hey guys,
    Intermittent
    Thanks
    There's a high chance that warranty is out the window now that you're tuned so it's probably not worth to mention. Some people have luck with getting warranty work done while tuned but most likely you'll be denied any warranty. Either way, I would clear the codes and see if they come back and check for vacuum leaks like others have mentioned.
