Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 162
  1. #81
    Jan 01 2018
    utah
    What are you using for vapor blasting?
    Sent from my SM-S928U using Audizine Forum mobile app
  2. #82
    Senior Member Two Rings eurogz's Avatar
    Apr 02 2021
    SE PA
    Quote Originally Posted by travis_w View Post
    Have a cabinet I can use at work. Similar to traditional media blasting but uses a slurry of glass beads, water, and pressure. Doesn’t have issues with dust and leaves a much more “factory” looking finish than any other media blasting I’ve used. That is how the majority of the parts on my block look so new:
  3. #83
    May 09 2012
    Virginia
    Did you have to cut out the firewall to accommodate the turbos back there? Looks like they extend a bit more than traditional framed turbos. They do look very fun though!! Nice work!
  4. #84
    Apr 02 2021
    SE PA
    Oh no doubt it’s gonna be tight but should fit. I am a bit concerned about heat but we’ll see how it goes
  5. #85
    Jan 01 2018
    utah
    I've been using a wire wheel to clean my stuff, but I'm thinking about buying a cabinet. I've always wanted one.
  6. #86
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    so what did you end up doing for pistons? did you stick to 81.5?
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  7. #87
    Apr 02 2021
    SE PA
    Quote Originally Posted by Gunnarrrrr View Post
    Went with JE 82.5. Was considering a Wiseco option but I was in a time crunch and I wanted the displacement bump
  8. #88
    Mar 25 2015
    Placer County
    Quote Originally Posted by eurogz View Post
    ahh big boy bore. did you avoid 83 because you wanted to play it safe with an APB block instead of a BEL, or just to keep a little material to work with in case something goes wrong?
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  9. #89
    Apr 02 2021
    SE PA
    Was trying to keep some meat in the block. In all honesty if this thing pops I’m fully expecting it to be violent enough that I would need a different block anyway haha. Counting the one that’s still in the car there is currently 4 blocks in my garage but one is being stored for a buddy until he’s ready to do an rs6 setup and one will probably be sold off. Also have a spare 01e that I was going to build but the one that is currently in the car has way less rust so I’ll probably just rebuild and reuse that one instead. Will slow me down in terms of time but I’m trying to keep this setup as clean as possible
  10. #90
    Jan 01 2018
    utah
    Deleted
  11. #91
    Apr 02 2021
    SE PA
    Saving a Santorin Avant
    Picked this stuff up from the coater today, camera doesn’t do the color justice. Looks very blue in the pictures, looks very purple in real life. I was shooting for “blurple”, I’m happy with it.
    Waiting on a power steering pump that I forgot to order, then there’s really nothing else I can use as an excuse to stall working on the turbo lines. Main concerns are coolant feeds as there is pretty much zero room behind the motor mount brackets, and oil drains as -10 fittings are substantially smaller than the oem drains
  12. #92
    Jan 01 2018
    utah
    That looks good. What did they charge and did you take the baffles out?
  13. #93
    Apr 02 2021
    SE PA
    225 for both valve covers and the manifold with 2 stage powder. Baffles were not removed, I specifically asked about it and coater said he just masks them off and has never had issues. There is for sure some media inside the intake manifold however which I’m kinda pissed about but will just have to spend time cleaning I guess
  14. #94
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Unless he used baking soda I’d spend a bunch of time cleaning it out. Sand/glass can get embedded and be a pain to remove completely. I’ve lost an engine after not cleaning it out well enough
  15. #95
    Apr 02 2021
    SE PA
    Yeah I’m gonna drill out the baffles and bolt them back in. Those are not dice I’m willing to roll. Manifold is easy at least since the plenum cover is removable
  16. #96
    Apr 02 2021
    SE PA
    Drilled out the baffle on a spare valve cover I have, there is definitely not enough meat to tap for bolts so that plan is out. Guess we’re just going to spend a lot of time rinsing and pray.
    If anybody has any other ideas for removing and reinstalling the baffles I’m all ears.
  17. #97
    Jan 01 2018
    utah
    Did you make sure the inside of your oil pan was 100% free of the glass beads?
    I just painted my valve covers, so I didn't have to mess around with taking the baffles out. I used etching primer but I still think it's going to flake.
  18. #98
    Apr 02 2021
    SE PA
    Upper pan was cleaned pretty thoroughly both after blasting and after machining, that I’m not super worried about. Lower pan is new
  19. #99
    Jan 01 2018
    utah
    Cool. The engine looks great. Going to be an awesome car.
  20. #100
    May 01 2022
    Denver
    Is that a oxygen sensor bung on your manifold? Apologies if you already know this, but if you plan on mounting a wideband in your manifold be aware that without pressure compensation the lambda reading won't be accurate. The absolute deviation in accuracy spans 80%, so the inaccuracy isn't insignificant. In order to account for the inaccuracy you need a controller which can compensate lp (pump current) based on pressure.
    You can see a graph for the amount of inaccuracy in Bosch's datasheet for the ADV LSU: https://www.bosch-motorsport.com/con..._pre_Turbo.pdf
    New to Audis, not to cars.
    My C5 Allroad build.
  21. #101
    Apr 02 2021
    SE PA
    Good info!
    Those are EGT sensor ports, the front o2 sensors will be in the downpipes (which I haven’t showed off yet but they are beautiful!)
    and wideband will be further back. Downpipes back haven’t been mocked up yet but will probably be full 304 stainless, 3 1/2” single to dual outlet with either a single muffler or single resonator (again haven’t even really thought about how I want to lay this out yet)
    Stock EGT sensors are pretty much useless so I have been kicking around the idea of wiring an aftermarket set of EGT sensors into an FIS Control to monitor, but with e85 and no cats I’m not really concerned about EGT’s being an issue, may just plug them and code them out
  22. #102
    Jan 05 2010
    burnaby british columbia
    Looks great. Who made manifolds and what are specs for turbos?
    Sent from my SM-A715F using Audizine Forum mobile app
  23. #103
    May 01 2022
    Denver
    Based on the location I assumed it was for an EGT sensor, but the bung looked quite large for an EGT sensor. It's probably just the shadows playing tricks...
    I agree, on E85 you shouldn't ever have to worry about EGTs. With that said, having the additional information wouldn't hurt. Definitely don't bother with the factory EGTs - the minimum temperature they can report is 945ºC, which I doubt you'll ever hit on E85.
  24. #104
    Apr 02 2021
    SE PA
    Quote Originally Posted by replica_rs4 View Post
    James Young made the manifolds, downpipes / wastegate pipes, inlets and charge piping. As far as I am aware he is the only person offering a kit for the G series turbos on the 2.7t currently, he’s sold a bunch of kits but don’t think many cars are on the road yet. There was another kit that used to be available in Europe I don’t see being advertised anymore. I know White Dog Racing built at least one car while they were still around, and I know a guy local to me that built his own setup in a swapped B6. Several running cars in Europe I’m only aware of a couple in the states.
    Turbos are G25-660, flow is supposed to be comparable to the gen 2 GTX3071R with better efficiency and a smaller size.
    https://www.garrettmotion.com/racing...eries-g25-660/
    Quote Originally Posted by Tightmopedman9 View Post
    The RS6 EGT sensors read from -40C to 1110C and would be the “ideal” solution which I’m still entertaining. I do agree more data is always a good thing. I was offered the option of individual EGT bungs per runner which I may have done if I didn’t hate the idea of a standalone setup vs stock ECU. My buddy is building a car with a FuelTech setup and I’m super jealous of the functionality but it’s not very “street car” and I love the idea of a wolf in sheep’s clothing
  25. #105
    Nov 13 2018
    Ocean city NJ
    Pretty sure Ignitron allows extra inputs via Can-Bus. So if you got a EGT controller that can send the messages via can you’d be able to log them also…all in a mostly PnP ECU.
  26. #106
    Jul 29 2023
    North Chicagoland Suburbs
    STUNNING!
    Love this thread and thank you for the continuous updates!
    __Mr__Griff
    2001 Audi S4 Santorini Blue
    2023 Jeep Wrangler Sport S High-Velocity Yellow
    1995 300zx Aztec Red
  27. #107
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Looking good. Nice headlights
  28. #108
    May 10 2018
    MA
    Quote Originally Posted by CELison View Post
    Headlights with good lineage too
  29. #109
    May 01 2022
    Denver
    Yeah, but RS6 EGT probes are minimum $399... You can just get a K type thermocouple for $20 and an Auber Instruments 1/16" DIN gauge for $50. Shoot, I have a spare gauge I'd just give you if you paid for shipping. Based on the rest of this build I guess cost isn't much of a consideration.
  30. #110
    Apr 02 2021
    SE PA
    Making sporadic progress. Made all my turbo lines, buttoned everything else up about 90%. Considering engine “complete” at this point. Once I pull the old engine I’ll finish up vacuum lines / wastegate lines / coolant hoses etc. There’s a local B5 meet in a few weeks I want to drive the car to, after that it’ll get parked on the lift and I’ll start working on the big stuff: trans rebuild, tubular subframes, fuel system etc. Still not 100% positive this motor will fit in the bay without some serious massaging.
    Side note several B5’s have been on my lift since I put it in but mine never has lol.
    In the mean time I’ve been jamming out some small stuff that’s been on the back burner while building the motor. Parts pile was getting to look like more of a parts mountain so happy to get some of it on the car:
    Replaced cracked hazard trim and dash cupholder
    Replaced exterior ambient temp sensor
    Replaced temp sensor in the center hvac duct
    Replaced cruise control stalk (shout out to Adam, but now my wiper stalk looks old and faded!)
    Installed the FIS Control
    Fixed a peeling door card
    Replaced all 4 door handle springs
    Replaced all 4 door speakers
    Replaced rear passenger window regulator
    New hood strut and hood latch
    Verified climate control unit was not causing my blower issues, guess I need a blower motor / resistor.
    Now working on rebuilding 6 calipers for my 18Z setup, hoping to get them mounted and bled this weekend. Fronts should be easy rears may be interesting.
    Posting pictures on this forum is such a pain in the ass from mobile or I would update more, Facebook / Instagram sees this build more frequently
  31. #111
    Nov 06 2021
    Victor ID
    Awesome build! You replaced all 4 speakers, what did you replace them with? My speakers are blown and need replaced.
    01 B5 S4 Avant
    Sold 02 C5 S6 Avant
    Sold 01 B5 S4 Avant 6 Speed Stage II
    Sold A3 TDI
  32. #112
    Apr 02 2021
    SE PA
    They were just some 2 ohm replacements from PowerBass, 5.25” fronts and 6.75” rears with 3D printed adapters to mount them in the door cards. Nothing special but sound much better than the 25 year old blown factory speakers.
    Brakes are coming along, need to finish up one e brake caliper and get them bled. Probably going to roll the front fenders and put spacers up front. No clearance issues with the v710 / 18z combo but I don’t like how much the fronts tuck. Rears are perfect with the 10mm spacers I’ve been running but the fronts rub on corners with no spacer would probably rip the fender off if I added them now. Hoping I don’t hurt the paint but already have some paint work I need to do eventually anyway.
  33. #113
    Apr 02 2021
    SE PA
    Committed now. Other than breaking the line from the vacuum reservoir to the n249 everything came out smooth. 01E rebuild is the next milestone.
  34. #114
    Apr 02 2021
    SE PA
    Disassembly is always much more enjoyable than reassembly
  35. #115
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Making great progress, really enjoy seeing others bringing these cars back to life and putting in the hours. I remember rebuilding my 01e with the JHM kit over a decade ago.
  36. #116
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Garage and lift envy! Thanks for the updates and pics, love following along every update.
    // 2001.5 Pearl White B5 S4 Sedan 6MT
  37. #117
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Disassembly is always may more enjoyable than reassembly
    Is it that bad? How’d you get the nerve to open it up? I’ve got an extra 01E in my garage and I’ve always wanted to get into it, but I’m too chicken.
    Great progress!
  38. #118
    Apr 02 2021
    SE PA
    Just gears and bearings in a manual transmission no black magic! JHM video makes it pretty easy to follow along. I’ve done plenty of bike transmissions but this is my first time inside an automotive transmission. If you have a press and are handy it’s tedious but not “hard”. Worst part is getting the tail housing apart without the Audi tool, I used a bearing splitter and some nuts/bolts and popped it right off.
    Lift was the best purchase ever. Only thing the garage needs now is heat and insulation so I can actually stand working out there as it gets colder
  39. #119
    Jan 01 2018
    utah
    Did you have to cutout and pour deeper concrete for the lift?
  40. #120
    Feb 05 2007
    Portland, OR
    I think I’m qualified. I’ve got a 12 ton press, a lift, a heater , just not the balls, hahaha. I’ve watch the JHM videos briefly. Once I get my engine install done and some breathing room, maybe I’ll take the plunge. Thanks!
