Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 158
  1. #41
    Senior Member Two Rings eurogz's Avatar
    Apr 02 2021
    SE PA
    Buddy that runs a local yard is hooking me up with a spare BEL block and a complete set of 2.8 heads on the cheap… let the parts hoarding begin!
  2. #42
    Apr 02 2021
    SE PA
    Saving a Santorin Avant
    Have an appointment next week to get the car on the dyno and retune, finally got a laptop set up for logging. Took some baseline data on the drive to work this morning, ~60 degrees and 85% humidity:
    Somehow wasn’t logging ignition retard on cyl 3, and pretty sure my wideband factor/offset are wrong… have another log at cruising speed where gauge was hovering around stoich and logs show afr bouncing around 16. Will have to do the math on that one again. Hoping to see some improvements with a more aggressive tune. Still working on actually interpreting the data but fun to play around with.
    In other news scored a mk2 RNS-E at a killer price from a salvage yard that didn’t know what they had, starting to collect parts to do the retrofit.
  3. #43
    Junior Member Two Rings
    Apr 29 2021
    2019 B9 A4 Prestige Sport
    Corona, CA
    Looking good man! Don't mess with the bikes anymore?
  4. #44
    Apr 02 2021
    SE PA
    Quote Originally Posted by Ducati899 View Post
    Thanks! Only had time for one track day this year, have done next to nothing on the street. Still have 4 bikes at this point - dedicated 600 track bike, 1000 for the street, supermoto and a grom as play bikes. Supermoto is probably the most fun you can have with your pants on.
    Played with the wideband a bit more, still not 100% accurate. Gauge is showing mid to high 11’s at WOT full boost, logs are showing it a bit leaner with high 12’s. Did tick off a 3.82 FATS which is a bit more respectable. Picture of the laptop screen is shitty but am not home to actually upload a screenshot.
    Math for the X series is weird, it’s supposed to be a linear 0-5V but is really 0.5- 4.5V correlating to 8.5-18 AFR’s. I’m sure I’m just fucking up the equation, any input is appreciated lol. My fuzzy math put me at a factor of .0092777 with an offset of -9.5, that read lean so shifted offset to -9 which is close but still not right
  5. #45
    Apr 02 2021
    SE PA
    Results are in, 366hp/394tq. Was hoping for a bit more honestly, tuner said not to expect much more out of PJK04’s on pump gas.
    Will be running this setup for a while, don’t really feel like spraying meth and e85 isn’t really an option either. Next best options are rods and hybrids or just light piles of money on fire and go for g25-550’s Neither can realistically happen until I make some room in the garage and get the lift installed which is a ways out yet. Next big project is the RNS-E while I stockpile motor parts.
  6. #46
    Apr 02 2021
    SE PA
    Got my block. Yellow valve covers are hideous. Got it mounted on the stand where it will live for the next few months before I tear it down. Plans are probably 81.5mm Mahle pistons, IE rods, 2.8 heads. Strongly considering the vast girdle but not sure.
  7. #47
    Apr 02 2021
    SE PA
    Replaced power steering rack yesterday. Was preparing for it to absolutely suck ass but really wasn’t that bad of a job. Old rack was out and new rack was installed in about 4 and a half beers. Thought these racks had dampers but rack I pulled out was stamped with an Audi part number and did not have one
    Took it for a spin afterwards and was blown away with how much better it felt, almost zero steering effort. Didn’t realize my old rack was so beat. Still have a tiny amount of play in the wheel coming off center, not sure if it’s play in the column or what. Need an alignment done still, was able to set it toe pretty close to where it was before but car is darting a bit on me.
    Next to complete:
    Alignment
    Time Sert one wheel bolt hole in passenger hub, don’t feel like replacing the hub yet
    Fuel sender repair, still not able to find a replacement
    Fab a faceplate for the RNSE
    In other news Rack Doctor absolutely sucks, has been over a month since I ordered a rack from them and have gotten zero communication (not for lack of trying)
    Was able to get the rack I installed at wholesale pricing from a buddy, actually cost me less than the one from Rack Doctor
  8. #48
    Veteran Member Three Rings BENI_BOY's Avatar
    Mar 28 2009
    CT, FL
    Quote Originally Posted by eurogz View Post
    Next to complete:
    Alignment
    Where did you get the rack from?
    Audi Q7 | Audi B5 Avant Widebody - Gone but not forgotten
  9. #49
    Apr 02 2021
    SE PA
    It was a Precision branded rack, however the distributor I got it from doesn’t sell to the general public I had to use a buddy’s wholesale account. List price on the rack was $850 I got it for less than half that
  10. #50
    Apr 02 2021
    SE PA
    Went to repair the stripped wheel bolt hole today, when I started the car I had a super rough idle and wideband was pegged lean which was concerning. Pulled out of the driveway to head to the garage and had absolutely no power brakes which was extremely concerning lol.
    Found the the T fitting / check valve that connects the brake booster line to the accordion hose fitting had blown apart. Good thing it didn’t happen while driving. Glued that back together as a temporary fix, ordered some vacuum line and a new silicone maf hose so I can just bypass it completely and not have to worry about it.
    Time Sert idea didn’t work out, would’ve had to pull the hub to drill it anyway so just ended up biting the bullet and replacing passenger side hub and wheel bearing. Will do the drivers side wheel bearing and hub soon, main concern is just having the car ready for the alignment I have scheduled for Tuesday.
  11. #51
    Apr 02 2021
    SE PA
    Got the car back from the alignment, feels so much better. Rear upper eccentric is seized on the passenger side, luckily already ordered a set from RMode. Contemplating a full suspension refresh and getting some decent coil overs but just happy to be driving the car again
  12. #52
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Had the same deal with bolt seizing in the control arm.
    At least for me I had to destroy the bushing on removal. Figured it was a good time to replace all bushings in the rear which really made the car drive better.
  13. #53
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Good to see another new build thread---Looking forward to following your progress...
  14. #54
    May 10 2018
    MA
    awesome!
  15. #55
    Apr 02 2021
    SE PA
    Not much accomplished but parts horde is growing. Picked up my 2.8 heads today, already talking to a local head wizard about a full supertech build. Just need to get them cleaned up and pull the old manifolds before I drop them off. I’m case anyone was wondering the 2.8 exhaust bolts are size sawzall!
    Also picked up a set of SRP pedals, new maf hose and piping to clean up the pcv setup, a VAST girdle from Marshall, and a hardwired coil pack harness from Silverex. Would like to finish the motor in my supermoto before I start tearing down the BF block, have too many builds happening at once. Still need to order rods and pistons along with some bits and pieces before sending this block to the machine shop. Emailed Mahle about a set of 82.5 M142 pistons, have not heard back. If that’s not an option I’ll do 81.5mm Mahle pistons from Blake who will be tuning the G25 setup.
  16. #56
    Mar 24 2009
    New York and Toronto
    i dig it. you're making nice progress.
    Because S4 = Hooker
    - getslideways
  17. #57
    Apr 02 2021
    SE PA
    RNS-E installed, faceplate isn’t as nice as some others I’ve seen done but it’ll do. Not a body guy by any standards. Getting some minor feedback with the headlights on and the music off but pretty low on my priority list to be honest.
    Started tearing down my block, shipping out the upper pan and main bearings to Marshall to prep for the girdle. He has a TDI pump waiting for me already.
    Still need to order internals, can’t make up my mind about which way to go for rods/pistons. Pauter, FCP, Mahle all bouncing around in my head. At some point I’ll just say fuck it and order something but my ADHD gets the best of me sometimes.
    Bartering some labor with a buddy, helping him do a clutch job and some maintenance things while his motor is out in exchange for a spare 01E he has. That’ll get the standard issue JHM rebuild and center diff upgrade as time allows.
    Machine shop has everything for the 2.8 heads finally, should get some progress in that department shortly. Got some other secret sauce in the works, this should start looking like a real build thread pretty soon.
  18. #58
    Apr 02 2021
    SE PA
  19. #59
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    *Whistles LOUDLY!!!!!!!*
    Beautiful manifolds and snails. Love the purple too.
    // 2001.5 Pearl White B5 S4 Sedan 6MT
  20. #60
    Apr 02 2021
    SE PA
    Slowly making progress. Saved these 2.8 heads from getting crushed back in April, they were in pretty rough shape. Corrosion, carbon, cracked cam cap bolts, broken exhaust studs, an exploded spark plug and more.
  21. #61
    Apr 02 2021
    SE PA
    Sent them off for a full refresh with the following:
    Supertech nitrided intake valves
    Supertech inconel exhaust valves
    Supertech valve spring kit
    Supertech Ti retainers
    Supertech billet keepers
    Supertech stems seals
    Manganese bronze guides
    INA lifters
    Bapmic cam chain tensioners
    IWIS cam chains
    Elring seals
    Originally ordered Supertech guides but the OD on those was .001” too small and we were concerned they could potentially drop at temp. Ended up using a set of Canyon guides that measured right where they should.
    If you went to the Lo’e Show you might have seen these heads on display!
  22. #62
    Apr 02 2021
    SE PA
    Block was dropped off at the machine shop today. Will be about two months to get girdle fitted and rotating assembly installed. In the meantime I picked up a two post lift to install in the shop, then will be parking a pearl sedan on it. Trans will be coming out of that car as a donor to rebuild and use in the Avant, then I’ll sell off the rest of that car. At that point the Avant goes on the lift and I’ll be in build mode.
  23. #63
    Nov 13 2018
    Ocean city NJ
    Nice man!!
    Where did you source the guides from?
  24. #64
    Apr 02 2021
    SE PA
    Machinist sourced all the head parts for me, he’s on AZ as ‘88Jetta16V
    https://www.missionmotorwerks.com
  25. #65
    Jan 01 2018
    utah
    If you don't mind me asking, what was cost on those heads?
    Sent from my SM-S908U using Audizine Forum mobile app
  26. #66
    Apr 02 2021
    SE PA
    The heads themselves I scored for like $150 lol. The rebuild was not cheap… could absolutely have done it cheaper but I wanted it done right and paid for it to be done right.
    Full supertech valves / springs / retainers / keepers, 30 new lifters, new guides and seals, cam seals / plugs, new cam chains, new tensioners and gaskets, and oil galley plugs were over 2k. Think labor was another 2k. Don’t tell my wife.
    I usually don’t add this stuff up otherwise I start thinking about all the cool shit I could be driving instead. Spreading it out over time helps a bunch, part of the reason my builds always end up taking years to finish is I could never afford to do it how I want to all at once
  27. #67
    Nov 13 2018
    Ocean city NJ
    Hope your wife ain’t on here but Im thinking all of that was more like 5-6k. Lol.
  28. #68
    Jan 01 2018
    utah
    Nice. They do look nice.
    I've learned to add an extra $1000 on top of whatever people say.
  29. #69
    Apr 02 2021
    SE PA
    Hahaha - she could be lurking anywhere….
  30. #70
    Jul 29 2023
    North Chicagoland Suburbs
    Fantastic read-through. Very stoked to see the outcome of the 2 month wait here. We're gonna need some more pics!
    __Mr__Griff
    2001 Audi S4 Santorini Blue
    2023 Jeep Wrangler Sport S High-Velocity Yellow
    1995 300zx Aztec Red
  31. #71
    Apr 02 2021
    SE PA
    Spoke with the machine shop today, he doesn’t feel comfortable running 4032 pistons at the boost/power levels I’m targeting. Phone call to Mahle and they said not to use them either. Gonna look into Diamond or JE, anybody want a set of 81.5mm PowerPak pistons before I list them up somewhere?
    In other news lift is in and wired up!
  32. #72
    Apr 02 2021
    SE PA
    2 months was a bit of an understatement, but block is back on the stand and pearl sedan is no longer living on the lift.
    Time to strap some hair driers to this thing and send it to the moon
    Bonus pic of the pearl on its way to the crusher
  33. #73
    Apr 02 2021
    SE PA
    Officially have an assembled long block. Had to do quite a bit of clearancing to get the TDI pump mounted with the girdle
    You’d be surprised but this damn DLC washer was probably the most expensive part by weight out of the whole build
    Even with the big port ATQ heads I had to open up the intake ports quite a bit to match TheTuner’s intake manifold, 2.7 heads would’ve needed a ton of work
    The ATQ heads had some plastic pins in one of the intake manifold bolt holes on each head, I had to drill those out and chase the threads. Will be plugging the SAI ports with some aluminum 1/8 NPT plugs.
    Next is timing components and then I’ll start hanging turbos
  34. #74
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Always enjoy these build threads, engine is looking amazing.
  35. #75
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Very nice! Pretty much what I would love to do with my Santorin Avant at some point. What are your power goals?
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
  36. #76
    Apr 02 2021
    SE PA
    My main goal right now is just to finish the thing lol. G25-660’s with the setup I’m doing should push me well past 800 to the wheels on the “full beans” map
  37. #77
    Jan 01 2018
    utah
    Post pics of the plugged sai ports. Bout ready to do that on mine.
    Sent from my SM-S928U using Tapatalk
  38. #78
    Apr 08 2013
    Connecticut
    Enjoying your build---doing well!!!!
    Question-
    What might a DLC washer be--doesn't ring a bell....
    NO laughing now
  39. #79
    Jan 01 2018
    utah
    I'm pretty sure it's a diamond coated washer to help hold the crank gear from slipping on the crank. Some focus rs & st use that instead of a keyway on the crank and cam.
    Sent from my SM-S928U using Audizine Forum mobile app
  40. #80
    Apr 02 2021
    SE PA
    Quote Originally Posted by travis_w View Post
    I’m dumb and ordered the wrong plugs and taps then said fuck it and just ordered the block off plates from JAE, barely cost any more and I don’t have to bother with it
    Quote Originally Posted by LJS View Post
    Question-
    NO laughing now
    “Diamond Like Coating” supposed to increase friction with the crank gear and reduce stress on the keyway. Have heard stories of sheared keyways and any measures to keep the timing belt where it’s supposed to be are good insurance.
    Jumped ahead a bit as I was tired of this stuff being hidden in the parts pile
    Dropping off valve covers and intake manifold for powder tomorrow. Need to vapor blast the thermostat housing and finish up timing, then I’ll probably start clocking and plumbing turbos. Still not 100% sure whether I’ll be making entirely new braided lines or modifying the stock lines yet.
