Page 5 of 5 FirstFirst ... 345
Results 161 to 200 of 200
  1. #161
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    I hit 1389 on the stock blower with a 3.2 ratio and don’t see power cuts on the Ultracharger file
    I’ve never logged MAF when DA is -2000 or lower but I bet I’d hit 1389 for much longer if I did.
    Fred, it’s funny that you think 2 c or d level “tuners” know more about the Magnuson blower than the company that wrote the original software for it. 🤣🤣
    You don’t know that IAT’s weren’t the issue with the Magnuson. Summer hasn’t even started yet…..
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  2. #162
    Apr 08 2014
    I also have the Ultracharger file, and at 1389 the BPV opens to limit and hold a max of 1389, just like all the other files on the market.
    Post your datalog..
  3. #163
    May 20 2017
    New Hampshire
    Supercharger Porting Q&A and Resource Thread
    None of us are running the Magnuson file so none of our data logs are relevant to the discussion we’re having about the Magnuson.
    I hit 1389 on the Ultracharger file, but not for any sustained amount of time.
  4. #164
    May 20 2017
    New Hampshire
    Hit it 3 times during this pull.
  5. #165
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    That's cute ! This is what it looks like on a Magnuson 1740. (courtesy of Albertaholdings). Audizine%20Forum-1408063470.jpg
    Sent from my SM-S908U1 using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
  6. #166
    Apr 08 2014
    So, you hit it for a fraction of a second and then couldn’t sustain the value of 1389, doesn’t really prove your point.
    Nonetheless, show a snap of your BPV position or just share the datalog link, odds are even at such little amount you spent at 1389, the BPV still moved slightly.
  7. #167
    May 20 2017
    New Hampshire
    Quote Originally Posted by RoofRails View Post
    And like I said before, neither is running the APR Magnuson tune so you have no idea what they did or didn’t do to the tune.
    You/we can speculate all we want but don’t know what they did.
    What we do know is at that point, they were able to go faster than anyone else had before in shitty DA and 105 degrees ambient temps.
  8. #168
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    Don't feed the troll.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
  9. #169
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
  10. #170
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    Any update on this? I would think that a non-race port would really just be opening up the inlet and outlet like you're doing here.
    "Big" Mods:
    -APR turboback exhaust w/ gutted HFC
    -Intake
    -Treadstone TR8 intercooler
    -2014 A5 engine to fix the oil issue (REEEEEE)
    -Eurodyne Stage 2 tune (I did it myself. Fingers crossed.)
    Garage:
    2011 Audi A5 2.0T 6 MT
    1978 Dodge W-150 (318 cu. in. V8 w/ 4x4)
    2015 VW GTI SE two door DSG (Wife's)
  11. #171
    Mar 31 2008
    eS-4
    CAL*SO
    Their really doesn't need to be a term called a "race port".
    You either are gonna do the full job grinding all the required spots or your not. Why would any porter offer different levels?
    Even Brett quit doing that option years ago.
  12. #172
    May 20 2017
    New Hampshire
    Quote Originally Posted by Jezza View Post
    Jokerz stopped doing a port where he ground off so much material that epoxy was needed. He found that machining less material actually flowed close to the same amount of air and made about the same power. Close enough that it wasn’t even worth mentioning the difference in airflow.
    A more “aggressive” port doesn’t always translate to more power. The idea is to remove only as much material as necessary to get the job done.
    I will never buy a hand done port from anyone. It’s impossible to get repeatable results by hand.
  13. #173
    Apr 29 2018
    Race ports are still a thing. Brett only does like one a year for our platform when he comes across a particular variant of our blower that has more material supporting the bearing wall. What Brett has explained is that the amount of material you remove from the bearing support affects the timing of the rotors. That rotors act like valves sealing back against that wall. The ports that have very little material left in that area are considered race ports. The peak power gets made at a higher rotor RPM on a race port, so your you need more pulley ratio to take advantage of it, and as we all know, cooling becomes even more of an issue. Windows need to be cut in to the BPV area in order to remove that much material so you're creating another point of failure, so he switched to a good all around port that is optimized to a 3.25 ratio that you don't have to wring it out to take advantage of.
  14. #174
    May 20 2017
    New Hampshire
    Fred, what criteria does he use to determine what is suitable for a “race port”?
    Is it a specific compressor housing part number? A certain production year range? Just chance variations in the castings?
    Did he tell you?
    When I talked to him he didn’t mention anything about that but you’ve probably talked to him more than once unlike me.
    When I talked to him he just said he does the less aggressive port now because opening it up more didn’t offer any more flow.
  15. #175
    Apr 29 2018
    Did he tell you?
    It's an early variant of our SCs. If you look at the BPV area, it's solid , no ribs. I don't know the year/vehicle that they are found in. Screenshot_20230725_094437_Facebook.jpg
  16. #176
    May 20 2017
    New Hampshire
    Good info. Thanks.
    It would be cool to know what the part number variant was.
  17. #177
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    Ya'll are gonna flip here, but the last bit of power is by modifying the rotor blades at the inlet. By doing should have a similar effect to opening the case as Roofrails describes allowing much more inlet flow and changing rotor timing by a lot........Somebody do it!
  18. #178
    Apr 29 2018
    Quote Originally Posted by BrokeBichB8 View Post
  19. #179
    Established Member Two Rings Ibuckfitches's Avatar
    Aug 20 2023
    Alberta
    Looking to port my supercharger but I can only find Jokerz offering the service. I messaged Shane Horning and Performancebuilds months ago and received no response. With Jokerz it would be over $2000 given that I’m in Canada, shipping would be another issue. With the winters here (-30c) IATs are no problem
  20. #180
    Established Member Two Rings SuitedUp2The9s's Avatar
    Aug 08 2013
    2002 Audi S4 Laser Red
    Alberta
    Quote Originally Posted by Ibuckfitches View Post
    Contact VastAZ. He's your guy.
    B5 S4 - Laser Red // Stage III
    C7 A6 - Magnuson TVS1740 // 10.69@128
    2002 B5 S4 ll 2012 C7 A6
    Instagram ll Youtube
  21. #181
    May 20 2017
    New Hampshire
    Vast AZ is the only real solution right now. Brett from Jokerz told me he’s getting out of B8’s because he doesn’t make any money on them, all the guys that were porting blowers a few years ago like Shane Horning and Matty are hard to get ahold of, JHM offers porting but I’ve never seen anyone posts results from one so that leaves Marshall from Vast AZ.
    So far my Vast AZ ported blower is working out great. I’m able to run decent times very consistently now and am way less dependent on decent weather to run good times. It just performs all day every day now.
    In 80 degree weather with the port I’m able to run the times I needed 40-50 degree weather to run with the stock blower and that should just improve when boost season finally gets here. Marshall from Vast AZ is the only porter that is actually putting out work and showing results in 2024.
  22. #182
    Mar 31 2008
    eS-4
    CAL*SO
    If you are looking for a completely solid hand ported blower, ive got one ready to ship now, no waiting weeks.
    I learned from Brett, Matty, and Brad years ago right before they left the scene pre covid. With their information I am able to replicate all of the universal cuts and smoothing to insure maximum flow. No different 'stages', just one solid job all the way through so there is no confusion. I do these as requested, mostly local but there are a few of my ports floating around from folks that ive shipped to and haven't had a complaint yet from the folks who have my units.
    I purposely price my jobs low because 1) i am a long-time community member and 2) everyone should be rocking a ported blower.
    $1250 shipped (conus) gets you a completely ported blower all the way through, new bearings and fresh oil.
    send me a pm and ill square you away with a fast turn around time.
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
  23. #183
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    I've been doing a lot of research and speaking to a lot of people I know about power increasing for my car. I have been playing around with the idea of a ported or aftermarket blower. No matter what combo of fuel, blower, and cooling I start to research, in our cars the factory setup/system with the IC bricks sucks when you start climbing over 400hp (which is stage 2 and up).
    If I do take the plunge the only way I am doing it on my car is going to be using a cooling system that uses the AC refrigerant to cool the IC bricks. The likely setup will be eliminating the IC core in the front bumper and just running the chiller (the IC core would actually put heat into the system and is counter productive). I also plan on doing meth/water injection in addition to the Refrigeration cooler along with pump or race gas along with a rebuilt/stronger HPFP and a more stout in tank setup. (I don't plan on using any corn fuel).
    Using the above mentioned setup, I should be able to avoid any fuel starvation or detonation and keep the motor together and strong.
  24. #184
    Established Member Two Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    Quote Originally Posted by carguy19 View Post
    Sounds to me like you’re going to want to get the forced induction inter chiller universal kit. It’s not to be confused with the earlier inefficient killer chillers. Only about 1600 USD . I have one just not installed
  25. #185
    Nov 08 2020
    Atlanta, GA
    Marshall @ Vast AZ
  26. #186
    May 20 2017
    New Hampshire
    A real world 60-130 ported blower comparison done in about as even conditions as I could. The difference equals about 40-45 wheel horsepower in my case.
    Jackal 93 and meth tune. Vast AZ race port.
  27. #187
    May 20 2017
    New Hampshire
    The Vast AZ ported blower keeps dipping deeper into the 7’s.
    This is on Jackal’s E40 meth tune with VP Speed Sauce Plus.
    This is a 3.2 pulley ratio. With a higher ratio I am pretty confident it would be a consistent low 7’s car. It just runs 7’s every time I try now.
  28. #188
    Senior Member Four Rings
    Jun 08 2021
    PA
    What did you end up doing for cats? Did you get stock or something else?
  29. #189
    May 20 2017
    New Hampshire
    Quote Originally Posted by Nillious View Post
    GAS GESI 400 cell stock location.
  30. #190
    Aug 20 2023
    Alberta
    Just installed a ported blower from Fresh.S[emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]] and I just wanted to leave a quick review for his service.
    He acted very professional all throughout and provided helpful information while going above and beyond. His work looks very consistent with competitors with a significantly lower price. Attention to detail is incredible.
    If you’re looking for a ported blower I highly recommend him.
  31. #191
    May 20 2017
    New Hampshire
    Do you have any before and after port time slips?
    That’s how good ported blower work is measured.
  32. #192
    Aug 20 2023
    Alberta
    Unfortunately I live in deep snow (dropped [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]]cm last [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]hrs) (minus [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]]c) so I can’t really hit the track to guage anything. I can probably take a look at the airflow improvement in the logs.
  33. #193
    Sep 27 2024
    Las Vegas, US
    Hello everyone. Late to the party but interested in porting my blower for my c7 a6. I already have all supporting mods and currently stage 2+ Jackal tuned. Is Shane still in the game? Seeing options for ports, I also considered VastAz but want to see what others think
  34. #194
    Sep 27 2024
    Las Vegas, US
    Is this their race port? What other mods do you have?
  35. #195
    Jun 08 2021
    PA
    Anybody ever ported a charger on stage 1? Would the tune just bleed any extra boost you got. I have a spare charger laying around and have the equipment for porting.
  36. #196
    Aug 08 2013
    Alberta
    People have. If there's room on your stage 1 tune to increase boost to match the map_sp, then definitely.
    C7 A6 - Magnuson TVS1740 // 10.52@131
  37. #197
    Mar 31 2008
    eS-4
    CAL*SO
    Yup!
    That's how I started. Apr stage1/ ported blower.
    Does it bleed boost? Probably
    Was it overkill for mods? Probably
    Was it worth it? Yup.
    Highly recommend that you go for it, getting a ported blower early on will just augment the power increase of other mods as you add them. BUT! I think only if you know you will make your way to going stage2,tp, pullies and matching tb (in order to really maximize). Or for folks who are going all in on the under stuff maintenance and the blower needs to come off anyways.
  38. #198
    Mar 31 2008
    eS-4
    CAL*SO
    next ported blower will be ready this weekend.
    $1275 shipped, conus.
    optional 80mm tb kit.
  39. #199
    May 20 2017
    New Hampshire
    Any performance data on any of your ports yet Ted?
    How do they stack up compared to Vast?
  40. #200
    Mar 31 2008
    eS-4
    CAL*SO
    Sorry dude, i dont have anything for you. I do appreciate your continued interest though :) :) :)
