Results 1 to 6 of 6
    Active Member One Ring opinaca's Avatar
    Jan 25 2014
    MB SLK280 / CADILLAC CTS4
    Saguenay/Quebec/Canada
    Exclamation V6 3.0L 30V AVK Engine harness wiring diagram/ecu pin out
    Hi guys,
    please I need the complete pin out of the engine wiring harness to ECU and the other modules & connectors to the engine bay fusebox....
    Because a small fire in my engine bay melted some wires to the point they are fused together.
    Engine cranks but no firing.
    So I got to cut and splice them.
    I want to splice my harness for the injectors and ignition coils on the left side of the engine (cylinders 4-5-6).
    Please thanks.
    Veteran Member Three Rings pablolizarraga's Avatar
    Jul 18 2014
    "Hers": SQ5 His: 1966 Ford Mustang Coupe, 1965 Ford Mustang Fastback
    Los Angeles, CA
    Yikes! How did the fire start?
    Jan 25 2014
    Quote Originally Posted by pablolizarraga View Post
    A vacuum leak occured at the brake booster, making the engine exhaust manifold becoming too hot because engine was struggling and some plactic bracket & rubber caught up on fire melting some of the wiring.
    Thanks for the pics.
    Jan 25 2014
    OPI (2002 A4 b6 QUATTRO 3L V6 AVK)
    Jul 18 2014
    Los Angeles, CA
    Yup. Ive had the brake booster barb that connects at the firewall just snap off. Glad you no one got hurt. Good luck putting it back together.
    Jan 25 2014
    So far so good....rewired the ignition harness and brake vac pump, on the left side of my V6....
    The injection looked OK.
    Still have to replug 2 Oxygen sensors, 2 camshaft sensors plus the crankshaft position sender.
    And waiting for a used coolant reservoir.
