Results 1 to 19 of 19
Hybrid View
    Junior Member One Ring DuntLed_Racing's Avatar
    Jul 18 2021
    Chicago
    Found a Potential Solution to OEM Exhaust Valve Rattle
    Hi All,
    I've shared this post in a FaceBook group and I thought it was about time I posted it here. This is a “comprehensive” analysis / review (ie. a long post). A “Too Long Didn’t Read” is at the bottom of this post. Disclaimer - I am not an engineer nor do I pretend to be one. This is a review / solution based on my personal experience and research.
    Like some of you, I have removed my mid muffler/ resonator (whatever you want to call it) and replaced it with an X-Pipe. As a result, I have experienced exhaust valve rattle in Comfort and Auto mode while under load between 1,500 - 2,000 RPM while the valves are closed (at a certain threshold, the computer opens the valves). I’ve searched for a solution and I believe I have found one.
    The B9 S4 (and I believe the S5, SQ5 and many other Audi/VW Group vehicles) uses a Küster manufactured exhaust valve actuator. These exhaust actuators work via a servo motor turning a screw shaft, which turns a gear, which turns a coiled spring, which turns the exhaust valve (see image). Küster is a valve actuator supplier for many auto manufactures and their valve actuators are used by Dodge, Ford, Audi, Volvo, Mercedes, and many others. However, their valves are prone to rattle due to an engineering design choice / flaw.
    These actuators work as required under stock / OEM conditions but when exposed to enhanced / elevated exhaust “flow” they tend to rattle while in the closed position. The rattle is due to the play between the valve connecting shaft and the shaft opening hole to the actuator. As flow increases, it causes increased pressure on the closed valve and causes the shaft to bang against the opening for said shaft.
    During my research, I was able to track down a Dodge Charger / Challenger Forum that discussed valve rattle on Chargers and Challengers that had the “active exhaust” equipped in 2015 / 2016 model year (Dodge active exhaust uses the same actuators as Audi). These forums discussed the rattle being due to broken coil springs, lack of downward pressure from OEM springs, and elevated flow when mid mufflers were removed. The largest contributor to the rattle were the broken springs. The springs, according to the forum, broke due to the heat exchange between the exhaust pipe and the spring itself - which ultimately brittled the metal leading to the breakage.
    Dodge, becoming aware of this issue, contracted with Küster to manufacture “taller” and more robust springs to aid in this heat transfer starting with the 2016/ 2017 model year. As a result, breakages were less common and rattle was essentially eliminated due to increased spring pressure.
    I’ve seen on the FaceBook groups and Audi forums that stretching the OEM spring helps but the issue comes back in a few weeks. This, in my opinion, is due to the initial state of the OEM spring being compressed and when stretched, the spring will attempt to revert back to its original form (and overtime it will). I have also seen a replacement spring manufactured by ASR used but the issue comes back with this spring as well. The reasoning, in my opinion, is because the ASR spring maintains the same pressure (ie. same height) as OEM and only simplifies the coils. THE SOLUTION, is to purchase a spring that is already stretched from the factory / applies more downward pressure.
    Enter the DODGE spring. Because of Dodges change in spring design, they have created a spring, that when compressed in the B9 actuator housing, applies more constant increased pressure (over OEM). This increase of pressure causes the valve to stay in a more controlled / solid place while closed resulting in less / full reduction of rattle.
    The upgraded springs fit the OEM actuators perfectly since they come from the same manufacturer and the install did not take long. The car does not need to be lifted but it would certainly help if you’re not okay with working in tight spaces. To make thing even simpler, I would suggest removing the entire rear muffler section if possible (but this will add additional time and steps.
    I have included the DODGE part number below as well as the website I purchased the spring from. I supported a local small business that sells them in a pair and I would encourage you to do the same - if you are willing to spend a bit ($10) more. I have also included images of the OEM springs vs the Dodge upgraded springs (Dodge being the taller spring) as well as the actuator for reference.
    Since making this adjustment (in July of 2021), I have not had my rattle return (and I’m hoping it’s truly solved). I’ve put a couple hundred miles on the springs and actuated the valves as much as possible to ensure they’re broken in properly. While reading through comments on the FaceBook group, some have noted that their rattle still exists but at a much milder level after this install. Some have also suggested plastic heat wrapping the springs. I will not recommend the heat wrapping as I have not personally done it and I believe you may have an improper “seat” of the spring into the valve. As for those that still have a rattle, ensure your springs are properly seated in the valve during installation and allow for a break-in period. If the issue persists, your actual valve may be bad, especially if you have a fully stock system. As an additional suggestion - there are some “breather holes” on the base of the actuator housing plate (4 in total - you can’t miss them) that members of the DODGE community have said that spraying some white lithium grease into helped alleviate additional rattle until the grease eventually dries out and you need to add more. However, I have not tested this since my rattle has gone away.
    TOO LONG DIDN’T READ (TL/DR): To fix the exhaust valve rattle you need to increase spring pressure. Stretching the spring will not work as the springs want to return to their manufactured state. Dodge sells “taller” springs from the factory and when placed in the exhaust valve actuator, they add enough pressure to stop the rattle. The DODGE part number is below. However, please consider supporting a small business and purchasing the pair from the company linked below.
    DODGE part #: 68319331AA - fyi if you search this part number you may find images that look different to the ones posted. Those images on google are wrong. If anything, confirm with your local Dodge dealer or use the link below.
    Link to website where I purchased: https://mfer-1.com/shop/ols/products...xhaust-springs
    How to:
    1) Check down both side of the exhaust to see that the valves are open (the driver side - for LHD vehicles - may be a bit hard to see at first)
    2) Unbolt the actuator (requires a bit of yoga to get in comfortably if you don't have a lift) from the base. There are 3 nuts in total.
    3) Remove the actuator by lifting up. No need to unplug the actuator.
    4) Keep in mind the orientation on the spring that's currently attached to the actuator.
    5) Remove the old spring and replace it with the new one placing it in the same orientation as the old one.
    6) Reinstall the actuator ensuring that the spring properly seats itself in the valve head. Since this is a stronger spring it may take a bit of finessing or an extra hand to help hold it in place.
    7) Before it's all tightened up, check the valve orientation again to make sure they're both still open.
    8) If so, tighten it all up but be careful not to over-tighten as the plastic can split.
    9) Turn your car on and cycle between comfort and dynamic/individual to check that the valves are working as intended.
    Feb 10 2020
    Frisco/Texas
    Awesome! Thanks for the write-up!
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    Can confirm that this works. Ive had the fix for about 2 months now, and I haven't heard a single rattle.
    Super easy "mod" with great results.
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Jul 18 2021
    Chicago
    Quote Originally Posted by awdconnor View Post
    Awesome! Glad it's been working for you!
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    You sir are a lifesaver. A buddy of mine has some extreme rattle from the exhaust valves as well as I, and I've had my valves disconnected because of this reason. This was a very helpful write-up. Thank you!!
    Jul 18 2021
    Chicago
    Quote Originally Posted by brandonbanana View Post
    Hopefully this helps!
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    Thank you!
    Apr 05 2012
    Earth
    So what's actually involved here? Removing the bottom cover of the actuator, replacing the spring, and then reinstalling the cover? I guess I have the rattle as when I start up my car, you can hear sort of like a hollow rattle noise coming from the exhaust if you're standing behind the car. You don't notice it from the inside.
    Jul 18 2021
    Chicago
    Quote Originally Posted by JohnEnglish View Post
    Pretty much:
    1) Check down both side of the exhaust to see that the valves are open (the drive side - for LHD vehicles - may be a bit hard to see at first)
    Apr 05 2012
    Earth
    Quote Originally Posted by DuntLed_Racing View Post
    Pretty much:
    What happens if the springs are replaced while the valves are closed?
    Jul 18 2021
    Chicago
    If the valves are closed, you'll need to ensure the actuator is also in the closed position. By default, when the car is off, the valves are open. I would double check to ensure yours are open before removing the actuators. If you install with closed valves but the actuator is in the open position, the valves will work backwards from how they're supposed to (comfort will be open and dynamic will be closed).
    My best advise is to ensure the vales are open and install the new springs in the exact same orientation that the old ones are in.
    Jan 03 2020
    2019 Toyota Tundra Off-Road
    Texas
    My exhaust value is tapping during idle, which is annoying as heck. It sounds TERRIBLE. For $70 this seems like a steal to me, so I am going to give it a shot.
    Administrator Three Rings oesman's Avatar
    Oct 08 2016
    Houston
    Quote Originally Posted by Trentimus View Post
    My exhaust value is tapping during idle, which is annoying as heck. It sounds TERRIBLE. For $70 this seems like a steal to me, so I am going to give it a shot.[/url]
    I did this recently and the buzzing rattling sounds mine were starting to inconsistently make have gone away. There is still an initial rasp the exhaust makes cold for a few seconds, but I think that has nothing to do with the valves. I took a video of the install so I'll probably post it up soon. I wound up taking the exhaust off my car as I was doing some other work anyway, personally I think it's less work to do that or at least let it dangle down than trying to squeeze your hands in, especially on the passenger side. Maybe with slender hands, but you'd be working fairly blind.
    Jul 18 2021
    Chicago
    Quote Originally Posted by oesman View Post
    Great to hear that it's been working! Just watched your x-pipe instal video and I look forward to the valve fix video! I think the initial rasp will always be there (unfortunately) when cold. It's there even on aftermarket systems and even on other auto manufacturers so I believe it may just be the way exhausts are. I'm a fairly skinny guy so digging my hands around in there (while tight) ended up working for me but it was definitely a challenge. If I were to do it again, I'd lower the system a bit - seems like it would be much easier and maybe save me some time.
    Jan 03 2020
    Texas
    The company you recommended the springs from shipped extremely quick, but I haven't had a chance to do the work yet.
    Feb 10 2020
    Frisco/Texas
    Replaced the old spring with the new one yesterday. Took 3 minutes and problem solved.
    Jul 18 2021
    Chicago
    Quote Originally Posted by ssanderson1 View Post
    That's great! Glad it worked out.
    Oct 07 2013
    Recently installed a 034 high flow cat, and shortly after I started getting this buzzing from the exhaust on startup and driving at low rpm in D mode.
    It was driving me nuts as I was checking everything but couldn’t solve the rattle/buzzing. So glad I came across this thread. I just installed the new springs and it solved the issue!
    I think the higher flow from the new HFC was causing more pressure in the exhaust system and causing the valves to rattle. The stiffer spring seems to have cured it.
    Thanks for this post!
    Jan 11 2024
    San Diego, CA
    Thank you for this write up. I had a similar rattle on my AMG Mercedes with these Küster actuators and this post fixed 100%.
