Results 1 to 12 of 12
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Codes for Vag Com, Window codes, Door lock codes, Fog light codes?
    I have a 2004 A4 and Im meeting up with an AudiForums member soon and I was wondering what the codes were for the windows going up with the remote, the doors automatically lock after 10MPH, and Fog lights go on independant from headlights...
    If you can tell me the exact code, that will be great. Thanks again.
    In Limbo Four Rings Sydeshow MO's Avatar
    Sep 14 2006
    B6 Avant-Xterra-FORD p/u
    NOR*CAL, Vallejo
    I just did all of the above. I forgot what the code was for all that. I searched for it and found it here on AZ.
    Fogs wont work on 04'. You can try to re-wire though.
    Veteran Member Three Rings midn12ght's Avatar
    Jun 17 2004
    socal
    not sure if these will work on b6's
    http://www.audiworld.com/tech/elec.html
    You mustn't be afraid to dream a little bigger darling...
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    yeah, i would like to know as well
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    actually you can. if you set your ligthing set up to canadian then they will always turn on
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    2004 A4
    Central Jersey
    How do we do it on Vagcom? What are the actual codes??
    Established Member Two Rings Graffe's Avatar
    Sep 14 2006
    2004 Allroad 4.2, 2005 A4 3.0Q
    Woodside, CA
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    Codes can be different for each car depending on how it is setup. So you'll have to do the math for each module. Read the page slowly (the linked one) and it will make sense.
    <Insert Signature Image Here>
    Sep 14 2006
    New York, NY
    You do it under the adaptation and recoding. I'll look for it.
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2004 A4
    Central Jersey
    Thanks GTMRS4... bump incase anybody else can help out..
    Registered Member Two Rings Dannyboy's Avatar
    03 Audi A4 3.0, 1995 Saab Aero
    California
    Now we can correlate the bits with the chart
    for Adaptation Channel 62:
    State Bit Dec. Function
    ON 0 1 windows up with remote
    ON 1 2 windows down with remote
    ON 2 4 windows up with key in lock
    ON 3 8 windows down with key in lock
    ON 4 16 sunroof close with remote
    OFF 5 32 sunroof open with remote (does not appear to work)
    ON 6 64 sunroof close with key in lock
    OFF 7 128 sunroof open with key in lock (does not appear to work)
    before you change any values, write down the old one first, that way if you screwed up, you can alway go back to original.
    Sep 14 2006
    NOR*CAL, Vallejo
    Just change your code to 6200, This will give you remote windows up/down, 10mph door auto lock, chime when armed, seatbelt chime off, One touch 4 door unlock.
    R0N thanks for the hook up BTW... My VAG-COM is registered!!!
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i paid 25 CND to do them all, not that much...so....
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
