Results 1 to 16 of 16
    Junior Member One Ring
    Sep 08 2021
    Socal
    Jeep Engine swap
    Hey all,
    This story starts three months ago I bought a 2006 B6 S4 at an auction not running. The usual skipped timing and dropped valves story. I got a donor engine, rebuilt it with RS4 parts and everything new I could throw at it. Drove it 20 miles and then found out the car is not allowed on the road due to title issues that are non reversible (thanks to the auction house for doing this, was totally avoidable and was filed incorrectly)
    My main passion is off road, specifically Jeeps and Prerunners. I have a 1989 Jeep Comanche that needs and engine, and a perfectly running B6 S4 in the backyard ready to go.
    I have built and done a few engine swaps, mostly American motors, LS, SBC, stuff like that. So I understand the challenges of engine swapping stuff.
    I have a few concerns with this swap though mostly due to the complexity. Running a standalone ECU is an option, but I would prefer to keep the stock ECU so I can retain the factory Paddle shifters, and trans controls. I would need to trim down the Harness Extensively and disable numerous things in the ECU. If doing that is feasible, and somewhat logical then I would prefer to do that.
    If that doesnt make sense to do, I can do a standalone and find a manual trans locally to put behind it. (recomendations on what standalone is best for a stripped down BHF appreciated)
    In either scenario I would weld the center diff and run it in RWD option UNLESS someone knows of a RWD only trans that will bolt to the engine thats easy to get?
    The items I wouldn't need, that would hopefully be disabled or fooled are:
    -ABS
    -Traction Control
    -HVAC
    -Immobilizer
    -Wheel speed sensors
    -Steering angle sensors
    -all interior comforts
    -Airbags
    -Parking Brake
    -PCV system
    -Secondary air pump system
    -Fuel system sensors
    -Key FOB
    The items that are preferred but optional to keep are:
    -cruise control
    -Auto transmission controls
    -Paddle shifter control
    - Oxygen Sensors
    The items that are definitely needed are:
    -only things required to keep the engine running and transmission shifting if I can keep the auto
    I know this seems like a crazy plan, but lets imagine for now that the build has unlimited time frame, but not an unlimited budget.
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    I’m sorry I don’t have much to add yet, but this project looks awesome. So I’m subscribing in order to keep tabs
    Sep 08 2021
    Socal
    Put my old ruined engine together enough to see how it would fit. Looks tight but doable
    Sent from my Pixel 5 using Tapatalk
    Junior Member Two Rings
    Oct 23 2021
    Ohio
    Wow, this is an awesome project. I'd suggest getting in touch with Jackal Tuning to see how much they can help you out on the "delete" front. I believe they sell ECUs with the immobilizer defeated which is probably a step in the right direction for you and I'd guess they can also switch off at least some of the things you're looking to delete.
    • 1/1 Northern Blue Pearl 2005 (B6) S4 Avant 6MT
    • 1/(who knows) Tornado Red 2016 Golf R 6MT
    Sep 08 2021
    Socal
    Quote Originally Posted by copperbricks View Post
    Glad to hear you like it!
    I did email back and forth with Matt @ jackal motorsports this morning. With the immobilizer turned off it'll run, but getting the auto trans to be happy with all the drivetrain sensors removed will be a problem. So I could strip the harness and do a manual swap...or I could just do a manual swap and do a standalone that will fight me a lot less than the stock ECU would. Looking into that tonight.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    This is going to be awesome, way better than the old Cherokee 4.0s.
    Looks like you might need a modified hood to fit the intake manifold and oil filter, but a hood scoop there would help with the heat issues, anyway.
    Good idea going to Matt at Jackal.
    Does the oil pan extend down a bit low? Perhaps a metal Thor plate (or similar) would protect it well enough
    Sep 08 2021
    Socal
    Quote Originally Posted by Zolli View Post
    A cowl hood will more than likely be required, no problem with that though.
    I am still playing with engine placement, so the oil pan may or may not be an issue still
    Sep 08 2021
    Socal
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Sub’d for updates as this looks like a fun project you’re pursuing. Reminds me of the folks who successfully did a 2JZ swap into their Audi but this is just the opposite. Best of luck OP!
    Cheers,
    Ry-man
    Sep 08 2021
    Socal
    Quote Originally Posted by CONative View Post
    Thank you! Oddly enough a 2JZ bolts up to the existing jeep transmission, but I'd still rather do the Audi swap.
    Sep 08 2021
    Socal
    Does anyone have a B6 or B7 S4 throttle body lying around to take measurments on the bolt pattern?
    I am going to run a megasquirt on mine and will need a DBC TB. Need the spacing to get one ordered.
    May 06 2015
    If nobody else chimes in I can get you these tomorrow as my engine is currently out.
    Cheers,
    Ry-man
    Sep 08 2021
    Socal
    Would really appreciate that!
    Nov 12 2015
    Oregon
    Quote Originally Posted by Cgaines98 View Post
    I can get you this. Give me a few
    Btw... love the project. I've done the manual swap on the s4. If you go that route and get stuck, let me know.
    Sent from my SM-N960U1 using Tapatalk
    My build log
    Nov 12 2015
    Oregon
    This is The side that connects to the elbow on intake manifold
    My build log
    Sep 08 2021
    Socal
    Very Much Appreciated!! Thank you.
