Had the engine light pop on while driving, plugged the VAG-COM in when I got home and found P2006/2007 faults, IMRC flaps stuck closed, bank 1/2. Cleared them and they came back. Have not noticed any difference in day to day driving since the codes were observed. And I haven't done anything to the car lately that could have caused this - no service, taking off the SC, etc.
I got a vacuum pump tool to see if it was an issue with the vacuum lines running from the solenoid to the actuators. They hold vacuum, and things seem to be working when vacuum is applied - I see a voltage in VCDS when I go the Engine module, Adv. Meas Values, on both banks (sorry I took a screenshot of that but lost it so I'm going off of memory here). So this suggests the vacuum lines are fine, the actuators work, and the sensors are sending back a signal that the flaps are moving.
I logged those same values in the Engine/Adv Meas Values screen during a ~4 mile drive around the neighborhood - never saw any changes. So, I think the flaps aren't moving at all.
I'm thinking the vacuum solenoid (vacuum regulator?) is bad. Of course, it could be a wiring issue too, or an issue with the module sending the signal to the solenoid. A new solenoid is about $125, so not terrible, but I'd like to go one step further to make sure there is a signal getting to the valve and confirm it is bad, before replacing that part. I have a multimeter and basic electrical knowledge, but not sure how to proceed from here. Can I force a voltage to the solenoid/regulator and then check for the proper voltage at the connector? I'd need help figuring out the pinout for that connector.
Any tips on this appreciated. Thanks!
