With windshield cowls becoming hard to find new, I wanted to discuss options for replacing the old, cracked cowls that many people have.
I have seen options where people are cutting the original rubber strip off and adding/glueing a new seal on. This seems like a decent approach that I may try with my car… but…
It appears a B5 Passat cowl fits. There is a spot in the middle for the factory clip, as well as a tab on the right side for a clip. It appears the B5 S4 has the metal mounting tab on the right side, it just needs a clip added to secure it. Left side does not appear to clip/mount like the right side does.
So from what I noticed, here are the issues one would have using this piece.
1. Mounting of the right (passenger) side.
2. The wiper holes are slightly larger. Will need to use the B5 Passat grommets to properly fill the gap, or come up with something custom. Neoprene washers perhaps?
3. Cabin air filter lid does not exist on this piece. Use Passat, or cut old S4 piece and use that?
4. There is nothing to keep it “clamped down” against the windshield. Because of this, there is a gap between the cowl lip and the windshield. I am not sure how the Passat handles this issue… I don’t see any tabs, clips, etc that would secure it down.
All and all, pretty minor issues in my opinion. I may attempt to move forward with it if I can find a cabin filter lid that would work properly.
