Results 1 to 11 of 11
    Jun 21 2021
    World
    Help with drl (2017 8V a3 Cabriolet)
    B9AC4557-C66C-4294-852B-B6C4EF948F2C.jpgHello everyone i am a new owner of an 2017 a3 cabriolet 8v owner but i got a problem with my drl its yellow and dim can i salvage it with obd eleven or do i need to change it thanks in advance.
    Mar 10 2019
    FL
    Quote Originally Posted by batuh View Post
    Hello everyone i am a new owner of an 2017 a3 cabriolet 8v owner but i got a problem with my drl its yellow and dim can i salvage it with obd eleven or do i need to change it thanks in advance.https://imgur.com/a/DjpfwCp
    The entire unit has to be replaced. Just happened to mine
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    You can open them...is a pain in the ass because they are permaseal but they can be open with lots of patience either by the heating them on the oven method or a heat gun or by cutting them carefully with a Dremel tool and the DRL leds modules can be changed. They use two LEDs one on each side to spread the light.
    You have the facelift headlights. It's the same method pretty much.
    I opened mine to do a RGB DRL. Here's the results.Screenshot_20210525-230712__01__01.jpgIMG_20210625_210105.jpg
    Sent from my IN2017 using Audizine Forum mobile app
    Jun 21 2021
    World
    Quote Originally Posted by TreizeRXH View Post
    I wonder if it is control module or headlight itself
    Mar 10 2019
    FL
    It’ll be the first thing they check but if that’s not it then the light itself has to go
    Jun 21 2021
    World
    Quote Originally Posted by Eli0073 View Post
    Looks cool but i dont want to kill my headlight
    Jul 17 2020
    USA And Finland
    I mean you don't need to do what I did. I'm just making the point that it's possible to open them and simply replace the DRL modules.
    Those are the DRL modules. They are plug and play. First picture the oem drl, the second pics is my RGB DRL. Once you open them is very easy to replace them.IMG_20210222_194402__01.jpgIMG_20210222_194347__01.jpg
    Jun 21 2021
    World
    Okay thanks a lot. By any chance do you have a link for a replacement video?
    Jul 17 2020
    USA And Finland
    Sorry I don't. When I did my headlights i looked everywhere and I was not able to find anything. Closest video was from the shop B8 drivers they do this mod for the B8 platform.
    You can take your headlights to a shop that does headlights mod and they can do it for you.
    I mean you can do the ice driver if you want. You really don't need to change the colors...even do they are RGB they will light white.
    US $140.00 | Icedriver for AUDI A3 S3 DRL RGB multicolor LED boards 2013-2015 daytime running lights Red Blue Demon Eye lighting bulbs
    https://a.aliexpress.com/_mMpzk61
    If you look on this link you can click where it says 4 emitting colors and you can select your facelift headlights.
    Or go with OEM drl modules. The hardest part is opening them.
    This video will help you a bit. All do in the S3 the DRL are hold by a bolt so once you remove the bolt they come right off no need to pry them.
    https://youtu.be/W9e8m5Fcez4
    Jun 21 2021
    World
    Thank i found a used headlight for 120$ in my town but i wonder if the lights are gonna match if i get a used one
    Dec 23 2015
    HOUSTON/TEXAS
    I have the same issue. I'm wondering how much a local mod shop will charge to do the RGB mod. What did you end up doing?
