Results 1 to 13 of 13
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Looking for an AGM battery code with no debate
    I'm well aware that the decision to code or not to code a new battery has been debated to death. Not trying to go down that road.
    I just purchased a Die Hard Platinum AGM H8 battery to replace my Factory stock Flooded battery. There is NO BEM code on the AGM battery, and the Ah rating is 95 amps, versus the 110 Ah of the conventional battery. I know I can just change one digit on the original serial number, and will at least do that, but since the Ah rating is different, I am hoping to put in a proper code.
    So, all I am asking is if someone has installed an AGM battery with a similar rating, what they used for a BEM code? I'd even ask if they could post it, and then I'd copy theirs if the battery rating is the same.
    DT
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I can understand your concern to get the correct code. This thread may be helpful: https://www.audizine.com/forum/showt...1#post13037823
    Perhaps you can DM "Redd" and inquire as to the solution he followed for his AGM battery.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Three Rings volvofan's Avatar
    Sep 10 2016
    MA
    I jumped into the deep end feet-first about this time last year when I upgraded to an AntiGravity lightweight lithium battery and had some problems with coding. Ended up learning WAY more than I expected to and documented everything here. All you need / want to know about how to tell your car exactly what sort of battery you've just installed is found in the first post.
    https://www.audizine.com/forum/showt...perage-ratings
    Hope this helps,
    -Jon
    2013 RS5 Coupe 57k; slower than an Apache... not by much.
    GO - ECS intake; LWCP / LWFW / FP; Kline headers & exh; HFCs
    STOP - Forgestar F14s; Michelin Pilot Sport AS4; Voshmods rear BBK; CCBs x4
    TURN - ALL the braces; EuroCode sways; PowerFlex inserts; KW HAS; SPC UCAs
    PROTECT - RMR xmsn cooler / bar; ECS shields; JXB bearing; AG battery
    A/V - RSNav S4 10.25"; JL 8W1V3 sub; Alpine MRV-M500 amp; lighted sills/rings
    OTHER - Weathertech; Ziza LEDs; RMR hoses; ALL the carbon fiber
    Jul 02 2013
    Quote Originally Posted by LYKUNO View Post
    Quote Originally Posted by volvofan View Post
    Hope this helps,
    -Jon
    Much appreciated, I will check out those suggestions and threads.
    Sep 16 2020
    West Michigan
    I believe that if you contact Advanced Auto through their website, they can provide the BEM code for you.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jan 04 2017
    El Monte/CA/United States
    You have to remove one of the stickers the Bem is under one of them, I bought a better from advanced auto regular lead acid and the bem code was under one of the stickers on top of battery
    Jul 16 2018
    Atlanta
    So you had a conventional 110Ah H9 (PR-J0Z, part number in your adaptation was probably 8K0915105F) before. And you have an AGM H8 now. You say it's 95Ah, not 92Ah? 95Ah would be more associated with a conventional H8. Anyway, if you know it's AGM H8 (PR-J0B), that would be 4F0915105E, such as came in my car.
    Jul 02 2013
    Quote Originally Posted by Smac770 View Post
    Yes, you are correct on the stock battery code. Re: Ah of the new AGM, I double checked and it is definitely rated at 95Ah. Thanks for posting that code of your battery, it corresponds to some of the info I have uncovered in my search and from the links others have posted. What make/brand is yours?
    I don't know why they make it so damn hard. As suggested, I even peeled off all the stickers trying to find a code on it, smh.
    https://shop.advanceautoparts.com/p/...xoC5fEQAvD_BwE
    Jul 16 2018
    Atlanta
    ? The vendor code and serial number are for warranty claim and log purposes. They do not impact the charging system operations. Mine was JCB from the factory and I left it JCB when I replaced my factory battery with another AGM H8. Just changed the serial number by 1.
    I've already been there done that regarding the 8K batteries, so I know the info is correct. https://www.audizine.com/forum/showt...1#post14358286 As for "95Ah", could simply be a test difference. H8 (group 49) AGM is still H8 AGM.
    Make sure you reset the date/time after connecting the battery before running the adaptation so that the history file for the J533 address seems intelligible.
    Jul 02 2013
    So here's my current battery profile:
    8K0915105F MLA 140620KOEQ
    The new profile using the AGM part number for a 92 Ah, and changing battery type to Johnson Controls ( JCB) and updating the serial number for the battery manufacturer date of 10/21, would look like this:
    4F0915105E JCB 211020KOEQ
    Does that seem logical?
    Also, I put a battery tender on the car when I swapped out the battery, so no stored data was lost on the car.
    Jul 16 2018
    Atlanta
    I disconnect the battery all the time for stuff, for several days once; data doesn't get lost that I've seen.
    As long as there's two spaces between E and J, looks fine.
    Jul 02 2013
    Thanks for clarifying needing 2 spaces between the E and J, since I was trying to figure out where to get a total of 26 Hexadecimal digits. I will try this today and post my results.
    Jul 02 2013
    Update:
    The new coding took without issue, thank you Smac770 for the tips. Here is my battery output tests before and after:
    Before:
    Address 19: CAN Gateway (8R0 907 468 P)
    14:29:59 Group 018: Power Supply (Battery)
    11.800 V Battery Voltage
    -12.5 A Battery Current
    11.0°C Battery Temp. (Estimate)
    12.0°C Battery Temp. (Ambience)
    14:29:59 Group 019: Power Supply (Battery)
    58.0 % Battery State of Charge (SOC)
    60.0 % Battery State (as shown in MMI)
    87.0 % Battery Aging (derived fr. Load)
    75.0 % Battery Aging (derived fr. Output)
    14:29:59 Group 020: Power Supply (Battery)
    4.2 mOhm Internal Battery Resistance (actual)
    4.0 mOhm Internal Battery Resistance (stan.)
    42 Ah Battery Capacity (actual/available)
    12.20 V Quiescent Voltage
    After with new AGM:
    14:52:56 Group 018: Power Supply (Battery)
    12.200 V Battery Voltage
    -12.4 A Battery Current
    13.0°C Battery Temp. (Estimate)
    14.0°C Battery Temp. (Ambience)
    14:52:56 Group 019: Power Supply (Battery)
    81.0 % Battery State of Charge (SOC)
    80.0 % Battery State (as shown in MMI)
    100.0 % Battery Aging (derived fr. Load)
    100.0 % Battery Aging (derived fr. Output)
    14:52:56 Group 020: Power Supply (Battery)
    2.6 mOhm Internal Battery Resistance (actual)
    2.2 mOhm Internal Battery Resistance (stan.)
    57 Ah Battery Capacity (actual/available)
    12.50 V Quiescent Voltage
