I have been frustrated for months now with a used 2008 A4 that was a basket case. Long story short, I solved everything but the convertible top and the bluetooth phone module not working right. I checked everything with the Ross-tech tool, and the phone module simply does not respond. That I can leave alone for the moment. The convertible top module shows only an improbable signal fault, which I erased. The issue is that the top begins to open by unlatching at the windshield, but then you can hear the hydraulic pump running, but nothing happens. What does happen is that it seems like the hydraulic flow is trying to close the top, even though it is already at the limit before the latching system takes over. The pressure in the system remains for a bit, then you can manually lower the top once the pressure abates.
I am sure that the pump is working properly and I checked all the solenoids for function. Is it possible that one of the position sensors is not closing or opening when it should? Is it possible that the solenoids are moving the wrong direction and causing the flow to go to the wrong hydraulic cylinder? When I say I checked the solenoids, I made sure that they clicked when I applied 12V to them. I can't be sure that they open fully, etc.
I installed a used roof ECU module from another A4 cabriolet but there was no difference in the roof function. Does anyone have any ideas on the next steps to attempt. Luckily it is not my daily driver, so I can take my time. The interior is mostly torn out at this point.
Any help?
