Results 1 to 12 of 12
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Car locking but won't unlock with fob
    Good day folks!
    Having an issue with my B8. Last week it started having trouble unlocking with the key fob. I've been having to pull the little key blade out and manually unlock the door.
    The fob will lock the car no problem but won't unlock it.
    When I press the unlock button the lights on the car flash like it's unlocking but nothing happens.
    Anyone have this issue and can point me in the right direction for a fix ? Thank you in advance!
    Audi Club Bay Area
    Senior Member Two Rings darren.kellum's Avatar
    May 31 2015
    UK
    I'd give a new key fob battery a try.
    Sent from my ONEPLUS A6013 using Tapatalk
    Dec 19 2013
    Quote Originally Posted by darren.kellum View Post
    Swapped it. Didn't do anything .
    Cars headlights and tail lights flash indicating the remote works but the car won't unlock
    Audi Club Bay Area
    May 31 2015
    UK
    Saw this the other day, probably won't work but I'll share anyway.
    https://youtu.be/GMtwyAnkYyU
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Latch time
    B6 S4, B8 A4, 8P A3, and something, something.
    Feb 15 2016
    Cambridge,Ontario
    all doors wont unlock or just one ? if its just one absolutely RPM is correct.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 19 2013
    All doors. They all lock no problem but none of them will unlock with remote. Any idea what this could be ?
    Audi Club Bay Area
    Dec 19 2013
    Quote Originally Posted by RPMtech147 View Post
    Latch time
    On all 4 doors though ? Is there some sort of module that controls this and would allow all the doors to lock but not unlock? I've never had this issue on any of my past 5 audi's I've owned
    Audi Club Bay Area
    Junior Member One Ring
    Aug 20 2018
    Cape Town
    Latch time
    This. But the actuator is repairable. Repaired mine a couple of years ago and it is still working. All other 3 doors won't unlock via key fob i must open them from inside.
    Sent from my SM-G965F using Tapatalk
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    You didn't say what happens when you're in the car and lock/unlock with the physical driver door buttons. Do all the doors *unlock* properly ?
    Any fault codes from J519 (BCM) or J393 (BCM2) ? --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Feb 15 2016
    Cambridge,Ontario
    when i unlock my doors i'm pretty sure they all unlock not just driver. Is that programable somewhere like most modern cars ? if it is i would first make sure that feature is set to all doors. Then see what happens.
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    "single door unlock" (iirc) in central locking in the CAR menu. I have mine set, so it unlocks only the door that I touch, or in the case of the key fob, driver's door and the fuel filler door on first unlock key press, the rest of the doors and the hatch on the second key press. But that setting would be irrelevant to the OP as his problem is the driver's door not unlocking.
    The OP's problem sounds like the door latch motor issue where it can lock but not unlock due to failure of the components internally, which can be repaired if you open it up. There were a few videos on youtube on the subject, search "b8 a4 door latch motor repair".
